MeelisV Tear DIY compressor ref.
Re: MeelisV Tear fiting solar
Postby MeelisV » Sun Apr 03, 2016 3:20 am
will make new cooler box
old one is absorption cooler 3way (12, 230, gas) works well but i like more
so
new cooler heart will be compressor unit Waeco cu-55 and evaporator vd-07
A woman has the last word in any argument.
Anything a man says after that is the beginning of a new argument.
MeelisV
Images: 105
Postby bdosborn » Sun Apr 03, 2016 10:04 am
I always wanted to try this approach but never did. Please post lots of pictures and let us know how well it performs.
Images: 806
Postby MeelisV » Mon Apr 04, 2016 6:19 am
i will make lot of pics and perform chart
i´m more pics then talk/write
but box is planned use inside and outside Aluminium composite panel 0,12 inch
and between insulation styrofoam 1,3 or 1,6 inch
MeelisV
Images: 105
Postby MeelisV » Mon Apr 11, 2016 12:31 pm
last summer trip from Estonia through Latvia - Lithuania - Poland to Czech
and one shock absorber attachment broke down
i had to remove shock in Lithuania after 600 km from start and i drove without it ~4000 km
now i repaired attachment
axle down
and away
i changed both socks and springs
old and new
cooler box visualizatsion vers. 1.0
it was no good because i cant find place for evaporator
now vers. 2.0
compressor down corner
let see how it goes vers. 3.0 ..... ?
MeelisV
Images: 105
Postby bdosborn » Mon Apr 11, 2016 7:03 pm
Your compressor fridge will use less power if you give the condenser unit plenty of air. Here's a thread you might like on the big RV site regarding condenser ventilation:
RV Fridge Linky
Images: 806
Postby TheOtherSean » Mon Apr 11, 2016 10:30 pm
I'm impressed by the cooler box build. I'm looking forward to watching it progress. Very neat.
TheOtherSean
Images: 111
Postby MeelisV » Tue Apr 12, 2016 11:51 am
bdosborn wrote:Your compressor fridge will use less power if you give the condenser unit plenty of air to breather. Here's a thread you might like on the big RV site regarding condenser ventilation:
RV Fridge Linky
Thanks
inside condenser there is ventilator (original)
it will cool compressor and condenser
and in cooler box compartment down i have fresh air intake and up - heated air suction.
and this ventilation tubing is connected with this fan
i will connect both fans work together
so i hope that it will be enough.
MeelisV
Images: 105
Postby MeelisV » Sat Apr 23, 2016 12:22 pm
dismantled all down again (cooler box)
and made some cuts and ...
used furniture corner profile (aluminium) and build it up again
MeelisV
Images: 105
Re: MeelisV Tear DIY compressor ref.
Postby MeelisV » Sat Apr 23, 2016 2:07 pm
first dry fit with insulation
insulation is 1,2 inch SPU insulation
planning attach insulation with double sided tape and fill joints with foam
cover later with same composite panel like outside
MeelisV
Images: 105
Postby Specktre » Mon Apr 25, 2016 9:45 pm
Hi,
I am looking for this kind of duct to insert a computer fan as well. Could you share where you get them?
Thanks :worship:
MeelisV wrote:and got 12V vent with 2,5" duct connections
now thinking how to control vent - 1....2....3 speed or smooth control and monitoring temperature
Specktre
Postby MeelisV » Sun May 01, 2016 7:51 am
Specktre wrote:Hi,
Thanks :worship:
sorry
so long time to answer
but i got my fan from there
http://www.t7design.co.uk/index.php/ventilation.html
MeelisV
Images: 105
Postby MeelisV » Sun May 01, 2016 7:56 am
not ready but you can see where i´m going
run out double sided tape so
MeelisV
Images: 105
Postby Shadow Catcher » Sun May 01, 2016 7:11 pm
Marine bilge blower 80786 Ours is throttled down using a PWM
Postby Specktre » Mon May 02, 2016 12:05 am
Exactly what I was looking for 8)
Thank you
Specktre
Postby warnmar10 » Mon Jun 19, 2017 9:54 pm
Oh nos! What happened to all the images in the middle of the thread?!?!?
"When a true genius appears in the world, you may know him by this sign, that the dunces are all in confederacy against him." - Jonathan Swift
warnmar10
