Just curious what weight some other finished loaded or unloaded 4x8 TD builds are coming in at. Trying to get an idea of where mine falls in line. Thanks.
Mine is at 850# loaded.
Rock wrote:I built the "Ultralight" that Mike designed way back in 2008 I believe. About 500 lbs without gear, but with a 6" thick memory foam mattress.
Eric
KCStudly wrote:This thread has the most comprehensive list and chart of trailer weights reported by their builders. Not all of the builders state that the weight given is from a certified scale with the camper empty, so it might not be completely accurate, but should get you close based on the law of averages.
