Mike S wrote:OverTheTopCargoTrailer wrote:I'm confused, everyone here keeps saying 30 amp service![]()
BUT there is:
30 amp x 120 volts 3600 watts max
30 amp x 240 volts 7200 watts max
Which are we talking about
I didn't know there was such thing as 30 amp /240 RV service. It would be a heck of a mistake to plug a 30 amp RV cord into a 240v receptacle!![]()
I thought only 50 amp service had 240 volts (120 x 2 hots) in the RV world. The OTTCT has 50 amp service right, being over the top and all
CoventryKid, we have thought about the kettle for heating hot water and haven't thrown out that idea. The simple kettle and two 5 gallon blue jugs under the sink one fresh and one grey seems sooo easy, but would we wish we had done it differently? Are you changing for ease or was heating the water an extra step you grew tired of doing?
CoventryKid wrote:Welcome!
I agree with Mike S. 30A service should be all you need.
I installed 30A when I converted our 7x16x7 aluminum trailer last year. We run 120v: fridge, hotplate, heater, laptop, printer, etc. and 12v: LED lights and water pump.
I installed a 15-gal fresh water tank during the build. After 6 months "on the road", I'm in the process of adding a 120v hot water heater for washing dishes, hair, etc. We did fine boiling the kettle for hot water; the hot water heater will make like just that much nicer.
Talking about nice, we use a porta-potti in our rig's small bathroom - my wife wouldn't be without this, nor would I. Means we can stop anywhere - simple luxury!
Good luck with your build. Don't hesitate to ask more questions!
McDave wrote:This would be an excellent opportunity to increase the insulation of the ceiling. Fir strips to build up to 2" and add the most insulation you can fit. Even just fir strips and an air gap will be better in terms of thermal transfer.
I need to think about the cut-off switch issue, but for sure isolate battery from all trailer functions while in transit, and maybe when in storage. You can still charge from TV and possibly run refer while in transit. But I would want everything else disconnected until you are set up at site and can monitor/manage systems. Just my .02
McDave
