Adding Solar Panel
Re: Adding Solar Panel
Postby Shadow Catcher » Mon May 30, 2016 9:01 pm
Bonnie what is recommended there is not necessarily the best choices.
Postby bonnie » Mon May 30, 2016 10:05 pm
Can you recommend anywhere that gives complete step by step on putting everything together?
Remember, the turtle won. :)
bonnie
Images: 107
Postby GPW » Tue May 31, 2016 5:30 am
Did you check You Tube ??? ... They have Everything on "How to“ :thinking:
Postby Shadow Catcher » Tue May 31, 2016 7:46 am
Bonnie it is more about which components, i.e. I have a 185W panel on to of the tear wires go from that to the input side of the Morningstar SunSaver and from the output of the SS to the battery. In my case I had to us the MPPT version because I bought a high voltage panel by mistake but the PWM version which is less expensive is a very good simple to set up controller. http://www.morningstarcorp.com/wp-content/uploads/2014/02/SS3.IOM_.Operators_Manual.01.EN_.pdf The battery is the one you have.
Postby bonnie » Mon Jun 06, 2016 8:06 am
I did buy a PWM controller. Rated for 400Watts.
bonnie
Images: 107
