http://www.mini2.com/forum/first-generation-faults-fixes/186817-mini-cooper-cvt-problem-solved.html
http://www.motoringfile.com/2011/12/15/bmwmini-sued-over-cvt-failures-in-early-minis/
jonw wrote:I have a CVT in my Honda PCX150 scooter and it works great for that application. However I'm less enthusiastic about having one in a (heavier) car, especially if towing. Interesting to hear some real-world towing stories from people who have them...
DrCrash wrote:So what cars have this "CVT" in them ¿
JaggedEdges wrote:15 years ago they were saying the same thing about electronic controlled automatics.... and there's still dinosaur shops around screw them up.
25 years ago it was fuel injection.
I expect they'll catch up.
Ford's CVTs seem to have been pretty robust considering what they put them in. Myself, I'd only deliberately buy one in a lighter vehicle at present, in fact I did, got one in a Nissan Versa Note, 2nd gen of Nissan's small CVT, so I figured they'd figured it out by then. I quite like it, can get almost full power and torque at any speed, and hold it. I say almost because the smarts are probably torque limiting things so as not to overstress the frictional parts.... which is why I see them as not scaling up terribly well, they only basically have a line of frictional contact around the belt. Can't make the belt much fatter and gain anything, because the outer part of the belt will be trying to move faster than the inner part of the belt on the cones it's clamped between. Only real way to scale that to big vehicles is duplicate, have half a dozen of the same thing in parallel, which of course means more complexity, plus adjustment/synchronization issues, one belt starts getting a little more than it's share of the load and it's gonna break. Or the other way is to go much larger, in which case your transmissions get to be twice the size of a normal one.
However, I'm still not sure that half of CVT complaints aren't user error, i.e. it's working as designed and the driver is freaked out by engine going up to 3000 RPM with light pedal pressure. Sure in a regular auto, that means some clutches are slipping. CVT, doing the cvt thing and giving you what you wanted the most economical way possible and it some instances that means higher engine speed, rather than lugging at lower revs... talking of such aberrations, saw someone who bought a 9 speed auto complaining that it shifted too much, I'm thinking, WTF did you expect, buy 9 gears and it only uses 3??? (Hey ford I'm looking at you again... 4 speed in the old Escort only mostly used top 3 gears, other gear was a low range 1st it scarcely used.)
But also it's been the case for years now that dealers will seldom actually get into a transmission or engine, they'll switch in a manufacturer certified rebuild.
