#1
Re: #1
Postby ghcoe » Sun Jun 05, 2016 2:17 pm
After drilling the wiring hole I then fed the wires through.
Feeding the wires
Now I need to mark where the tail light studs will go. I do not plan on using nuts on the back side, but I do need to allow room for the studs since they are not removable.
Marking the holes
Now I use a exacto knife to cut the holes in the canvas and deep enough into the foam for the studs. Then I can pick the foam out.
Cutting the holes
George.
ghcoe
Re: #1
Postby ghcoe » Sun Jun 05, 2016 2:21 pm
Now for the final test fit.
Installed
A couple of shots of the progress...... :twisted:
Nearly done
Nearly done 2
Hope for some more trailer time next weekend. :thumbsup:
George.
ghcoe
Re: #1
Postby KCStudly » Sun Jun 05, 2016 9:33 pm
Looking really good. As always, you are doing fine work, and when I say fine, I don't just mean 'okay fine', I mean fine as in high grade or quality. Very nice. :thumbsup:
Re: #1
Postby ghcoe » Sun Jun 05, 2016 9:47 pm
KCStudly wrote:Looking really good. As always, you are doing fine work, and when I say fine, I don't just mean 'okay fine', I mean fine as in high grade or quality. Very nice. :thumbsup:
A compliment coming from the master himself. Thanks.
George.
ghcoe
Re: #1
Postby GPW » Mon Jun 06, 2016 6:27 am
Well there ya’ go !!! :thumbsup:
Re: #1
Postby ghcoe » Sun Jun 12, 2016 6:47 pm
More progress on the trailer this weekend. I concentrated mostly on getting the hinge installed on the hatch. I found that with the hatch in position that it sat slightly higher than the roof of the trailer. I was already going to use a transition piece as a water diverter and as it turned out it was just the right thickness. I just had to install it under the hinge on one side rather than on top as intended.
Shim
The hinges that I purchased did not have any holes predrilled so I was able to space the holes where I wanted them to be. After drilling the hinge I was able to use the hinge as a guide for the aluminum transition pieces. The transition pieces are intended to act as a water diverter to keep water from freely running into the hinge area. What water hits the hinge area should be easily taken care of by the sub roof gutter.
Gutters
Gutters also keep light rain out of the sub roof gutter when the hatch is up. I am not sure if I will cover the hinge area with rubber or not. I guess I will see how this works first.
Hinge working
George.
ghcoe
Re: #1
Postby ghcoe » Sun Jun 12, 2016 7:04 pm
Here is a shot of the sub roof gutter with the hatch up.
Sub roof gutter
Next it was time to come up with a prop rod method. I went down a purchased two small casters rated at 50lbs. I think that should be enough capacity..... :R
Caster
Then I drilled out the axle pin.
Drilling
George.
ghcoe
Re: #1
Postby ghcoe » Sun Jun 12, 2016 7:11 pm
Once I got the axle drilled out I had this........
Caster disassembled
But, all I needed was this. :thumbsup:
Ex-caster mounted
Next, some conduit for prop rods. Turns out that one 10' piece was just the right length for two prop rods. How lucky is that :R
Drilling the prop rod
George.
ghcoe
Re: #1
Postby ghcoe » Sun Jun 12, 2016 7:21 pm
But, of course no bolts the right length.... :roll: Not going to let that stop me now.
Prop rod installed with caster
Then the test. Hatch deployed..... ;)
Prop rods in use
And of course they have to be stowed for travel.
Prop rods stowed
Still have to make a lock in device on the hatch for the prop rods. That will have to wait till next week. If all goes well. :NC
George.
ghcoe
Re: #1
Postby KennethW » Sun Jun 12, 2016 9:07 pm
{Lock devise for prop rods.}
I used a piece of PVC pipe with a wedge cut out so the prop rod snaps into the PVC pipe that is mounted on the inside of the hatch. But then I put the caster on the hatch so the rods swing down from the hatch and is stored on the inside of the hatch.
KennethW
Images: 82
Re: #1
Postby GPW » Mon Jun 13, 2016 7:09 am
Is there some way to secure the prop rods at the top ... just in case the odd wind wants to blow the top around ... :thinking:
Re: #1
Postby ghcoe » Mon Jun 13, 2016 6:36 pm
GPW wrote:Is there some way to secure the prop rods at the top ... just in case the odd wind wants to blow the top around ... :thinking:
I am working on it. Not sure how yet though. I have a few ideas I am working on.
George.
ghcoe
Re: #1
Postby loaderman » Tue Jun 14, 2016 3:18 am
Like the repurposed caster :applause:
loaderman
Re: #1
Postby lthomas987 » Tue Jun 14, 2016 1:50 pm
loaderman wrote:Like the repurposed caster :applause:
Me too!
My solution is way less slick. I think I might be switching to this!
Laura
Bike-Drop a Micro-Foamy Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=59274
My first Superlegarra-ish Foamy build http://www.tnttt.com/viewtopic.php?f=55&t=59049
lthomas987
Images: 204
Re: #1
Postby ghcoe » Sun Jun 19, 2016 10:52 am
I felt comfortable enough to weight the trailer for a near final estimate. Loaded everything that still needs to be installed inside plus a little extra to compensate for paint weight. Was not as light as I was hoping, but did come in under expected. 480lbs overall weight, 65lbs tongue weight :thumbsup: .
I still need to build a tongue box but that should easily come in under 20 lbs. So yes I am happy with the results. When I started to build I was thinking 500lbs was going to be tough to achieve. Once I started the build I was thinking 450lbs might be doable. At that time I was not even thinking of the addition of a tongue box though. With a tongue box and under 500lbs......YES! :D
George.
ghcoe
