3GKnight wrote:I supposed I'd put a block or something under them in case the ground was soft. Else you'd be putting more and more shims in over the course of a weekend.
Without having to drill for bolts, could you use u-bolts to hold some scissor jacks?
GuitarPhotog wrote:I use a couple of these screw-type stabilizer jacks
These are at Home Depot, but I think I got mine at Amazon
http://tinyurl.com/hfwy7tu
<Chas>
les45 wrote:GuitarPhotog wrote:I use a couple of these screw-type stabilizer jacks
I got mine from Amazon too.
<Chas>
The feedback on Amazon indicates the screws and nut simply sit on top and are not fastened to the base. Are they easily removable so that the bases can be nested for storage and travel?
KennethW wrote:I use jack stands at first. But found that I did not need stabilizers with a HF trailer. You may want to try your TD out to see if it has a lot of bounce.
<Chas>
