steve cowan wrote:Nice job you're doing on the conversion.What type of air conditioner will you install?
flboy wrote:Hi Martin, I was just checking out your cabinets. Looking Good! I'd have a hard time doing that.
Since my fine woodworking skills are lacking, I was thinking of making my cabinets so that just the doors make up the face... kinda of like kitchen cabinets. I found few places on line where you can order any size door you want and it appears they are cut and "machined" out of a solid piece of MDF board for a very nice contour. Since I am painting mine white (or gray... not decided yet) I was thinking that may be a good option. They are relatively inexpensive and I could build all the remaining (frame with Luan plywood and shelving) I'd probably spend more on wood, tooling, and etc. trying to do that myself.
Any thoughts on that? The link below is just one example of places that do that. These would be ~$10.80 a sq. ft. I am concerned on the MDF swelling.. but if I seal it wel land paint it, I'd think the humidity would not affect it?
http://www.cabinetnow.com/rtf/opr1/opr1 ... oCjvPw_wcB
flboy wrote:Martin, thanks for the pictures and write up. Those doors look great. I may give it a shot. What's the worst that can happen? I can always replace them if I don't like the way the turn out. I am going to have to look into a router. I do not have one nor have used one. I'd definitely like to add some rounding to edges and etc.. can't wait to see yours all done. Nice job.
Sent from my SM-N900P using Tapatalk
flboy wrote:I have been wanting to use diamond plate metal for trim in the toy hauler but that would be too expensive. Maybe I make the frames out of wood and use the diamond plate for the panels? That might really look good. :-) I'd get that nice "garage" look that I want and just use the diamond plate on the cabinet doors.
McDave wrote:Hey m.colley, and flboy,
PS. I have built doors by just cutting a piece of plywood (3/8?) to the final size needed, then just apply trim or moulding to outside face to look like rails and styles. I like to make my own trim from 1" x ? and running the 8' length thru the router table with an "Ogee edge bit". You can do 1 edge or both and obtain different styles just by changing the depth of the bit. You can mass produce it and stain or paint it in 8' lengths and then just cut and miter as required. Baseboards, chair rails, crown, door frame trim etc. You really don't need "clear" or "select" lumber but dried would be best so it doesn't warp or twist.
