7'*18' V-Nose Cargo Trailer Toy Hauler Conversion
Postby hankaye » Sat Jun 25, 2016 8:00 pm
flboy, Howdy;
Don, looks like some good progress. Fumes, know what I gots to say about'em???
Goes like this;
Chemicals :D ... know how to use'em :thumbsup: ... do not abuse'em :? ... chemicals :) ...
Better living through chemistry ... DuPont (circa 1966) :lol:
hank
hankaye
Postby m.colley » Sat Jun 25, 2016 8:20 pm
the flooring looks good Don, where'd you get it from? Yeah I know about the heat, even with my squirrel cage blower running WAO it was still hot. I came close to building a redneck AC just to cool the air down some but chose to take more breaks instead. Headed out before daylight to the hunting land in the morning for a cleanup day. We're starting early to try and beat the heat. Hope to be done by 12:00 at the latest.
Martin
m.colley
Images: 83
Postby flboy » Sat Jun 25, 2016 9:00 pm
m.colley wrote:the flooring looks good Don, where'd you get it from? Yeah I know about the heat, even with my squirrel cage blower running WAO it was still hot. I came close to building a redneck AC just to cool the air down some but chose to take more breaks instead. Headed out before daylight to the hunting land in the morning for a cleanup day. We're starting early to try and beat the heat. Hope to be done by 12:00 at the latest.
Martin
Martin, Thanks. I got the flooring from Home Depot online and had it delivered to the house.
Yes, with the floor and ceiling in I start framing. The first thing going in is the AC! Then I can close the door and finish in comfort. The fridge goes in below the AC, so I will have cold water and AC while I work! :thumbsup:
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby hankaye » Sun Jun 26, 2016 8:09 am
flboy, Howdy;
Just a thought, ... won't the heat from the fridge confuse the A/C's thermostat?
hank
hankaye
Postby flboy » Sun Jun 26, 2016 8:47 am
hankaye wrote:flboy, Howdy;
hank
I wouldn't think so. They will be isolated from eachother. The fridge will vent on the side up near the top and draw from the bottom. I am not sure where the AC thermocouple is, but is suspect it would be on the intake somewhere. Thanks for mentioning that.. I will make sure of where it is at.
Sent from my SM-N900P using Tapatalk
Don (Flboy)
flboy
Images: 378
Flooring
Postby CaptD » Sun Jun 26, 2016 11:33 am
I'm looking at that type of flooring for my build as well. Available in coin and diamond finish. Costco has similar roll out flooring as HD online. Its heavy but seems durable and should be easy to cut with a utility knife. The dirt is gonna be hard to sweep out with the raised pattern but a small blower would work ok. Don please give us the wet traction test - that is wet ramp and wet knobbies - while riding up and while walking back down the ramp. Please wear good traction shoes!! No flip flops!! Don't want to hear about you rolling down the ramp with your KTM. Maybe try out your wet shoes/boots for traction before moving the bike. I like the light grey color and the only things holding me back from buying are not knowing how slippery the flooring might be and the weight. I'm trying to keep my all aluminum framed trailer light as I'll be full timing in it. Been riding with DDS since 2007. I was going to buy a 2017 KTM 200 2 stoke but they stopped making them so looking at the 350 dual sport now. CaptD.
2015 Pro Line 7x7x24
2001 Ford E 250
2011 WR 250R
2007 KLR 650
2007 TW 200
CaptD
Re: Flooring
Postby flboy » Sun Jun 26, 2016 4:26 pm
CaptD wrote:I'm looking at that type of flooring for my build as well. Available in coin and diamond finish. Costco has similar roll out flooring as HD online. Its heavy but seems durable and should be easy to cut with a utility knife. The dirt is gonna be hard to sweep out with the raised pattern but a small blower would work ok. Don please give us the wet traction test - that is wet ramp and wet knobbies - while riding up and while walking back down the ramp. Please wear good traction shoes!! No flip flops!! Don't want to hear about you rolling down the ramp with your KTM. Maybe try out your wet shoes/boots for traction before moving the bike. I like the light grey color and the only things holding me back from buying are not knowing how slippery the flooring might be and the weight. I'm trying to keep my all aluminum framed trailer light as I'll be full timing in it. Been riding with DDS since 2007. I was going to buy a 2017 KTM 200 2 stoke but they stopped making them so looking at the 350 dual sport now. CaptD.
Right now I have the trailer backed up against the house working on it, so it would be hard to get the KTM in. The diamond plate has a better feel for traction; however, this is still a hard rubber, so I don't know how well with will be with wet knobbies. First chance I get I'll check it out. With the shoes it is fine.
Don (Flboy)
flboy
Images: 378
Postby flboy » Sun Jun 26, 2016 4:30 pm
Flooring a ceiling in (to be trimmed out later) and next up, framing begins. First priority is to get the AC installed! :)
Don (Flboy)
flboy
Images: 378
Postby Iconfabul8 » Sun Jun 26, 2016 8:51 pm
Looks good. I'm jealous. I can't wait till mine gets to that point so I can pause for awhile. I have other stuff to do but I am very one track minded. I am driving my family nuts with my ocd.
Iconfabul8
Images: 14
Postby Rainier70 » Sun Jun 26, 2016 8:54 pm
Your floor looks really nice, plus it should contain any spills. Seems like accidents happen when hauling bikes. :(
Rainier70
Images: 244
Postby flboy » Sun Jun 26, 2016 9:00 pm
Iconfabul8 wrote:Looks good. I'm jealous. I can't wait till mine gets to that point so I can pause for awhile. I have other stuff to do but I am very one track minded. I am driving my family nuts with my ocd.
Thanks... I know what you mean! I want to get mine done and still have a lot of work to do which I can only do on the weekends mostly. Can you believe my family actually wants me to spend some time with them!! :) :)
I had a goal of being done by the end of July... It's not looking good for that. But I should be done for some good late summer or early fall camping!
Don (Flboy)
flboy
Images: 378
Postby flboy » Sun Jun 26, 2016 9:04 pm
Rainier70 wrote:Your floor looks really nice, plus it should contain any spills. Seems like accidents happen when hauling bikes. :(
Cindy, thanks. It should contain spills and drips. It will be hard to sweep however with that raised pattern. I may get a real cheap electric blower as someone suggested. I can just open the ramp door and blow it all out. :-) I hope it holds up. We'll see.
Don (Flboy)
flboy
Images: 378
Postby flboy » Mon Jun 27, 2016 7:01 am
As is start my framing this week, I know I do not want to use 2x4's for the framing due to size and wieght. I was thinking about using my table saw to rip them down the middle and get two studs out of the one 2×4. Is this a bad idea? I think 2x4's would be overkill and I don't need the walls 3.5 inches thick plus paneling.
l would use the same for framing up the cabinets.
Thoughts?
Don (Flboy)
flboy
Images: 378
Postby lrrowe » Mon Jun 27, 2016 7:04 am
I think it is a good idea if you can control the tendency for lower cost 2 x 4's cut in one half to warp or twist.
Bob
lrrowe
Images: 439
Postby Spotman » Mon Jun 27, 2016 9:15 am
Old friend of mine many years ago, cut 2x4 in half, used old cans of spray paint, light coat. Prevents wood from warping when we built my 6x12 standy all from scratch. Worked great, never warped. Something to think about.
Sent from my SM-G920V using Tapatalk
2018 Heartland Terry Classic V21
2018 Toyota Tundra DC
Spotman
Images: 241
