Update #15
6-5-16
This weekend....man was it hot!!
Close to 100° all weekend
I was able to get some work done I have ordered my fenders, and the hurricane hinge so hopefully I can get those two things going soon...on to what I did get finished.
I was able to get the propane system setup as well as the grey water and fresh water system and also finished the galley cabinets
after testing this setup I realized the fill tube should be on the top because it was creating a ptrap type effect and the tank was only getting about 1/3 full before backing up the sink
Oops forgot to remove the circular saw from under there..lol anyways
The fresh water is the same size tank so I never have an overflow figured it was easier than trying to see how much I had and when is it going to be full..this way once the water stops coming up I know it's time to refill and empty the two tanks . The hose is just running through the inner cabinet wall to the fresh water tank.. also I have my propane line under there too..I was originally just going to have the line come out the cabinets when we were using the stove but I didn't like the way that looked so I was using our kayaks and noticed they have water tight hatches..I bought one off amazon and installed it in the side of the trailer now I can grab the propane though the side of the trailer and keep the cabinets closed
Propane access open
Propane access closed
Sent from my SM-N920P using Tapatalk
