McDave wrote:If you look at the spring, there is a device for winding and unwinding attached usually near the mid point of the axle.
You can put 2 steel rods or correct sized screwdrivers in at 90 degree angles to each other. Caution!! These things are dangerous!!! If you decide to attempt removing cable have appropriate safety gear on.!!!
You would want to put ramp down, then put rods into winding device so as to increase tension on spring. Position rods so that as you increase tension with 1 rod in right hand, you can put rod in left hand into the next hole that would be adjacent to roof or top frame to use as a stop. Rods or drivers need to fit well into winder but not too tight or loose.
So for example insert rod in right hand into hole at 6 oclock ,move it to 9 oclock and insert rod in left hand into the 3 o clock and allow rod to contact frame or roof. This should put slack in cable allowing you to remove it from ramp.
Again, THIS CAN BE VERY DANGEROUS!!!!!! PLEASE BE SURE YOU UNDERSTAND PROCEDURE AND ARE PROPERLY EQUIPT TO DO THIS. IF YOU ARE NOT CLEAR OR CONFIDENT, DONT TRY IT!!!
ALSO YOU CAN PUT RAMP ALLTHE WAY DOWN, THEN INSERT ROD IN THE APPROPRIATE POSITION TO STOP THE AXLE, THEN LIFT RAMP AND BLOCK IT UP TO INTRODUCE SLACK, THEN REMOVE CABLE.
DO NOT TRY THIS IF YOU DO NOT UNDERSTAND HOW IT WORKS!!!!!!
You may have slack when ramp is up, but it may be impossible to access nut and bolt.
Good Luck,
McDave
