flboy wrote:The AC is in and working awesome! it was 70 degrees in there when I came inside tonight. I am going to let it run overnight to pull out the humidity and then turn it up some tomorrow and see how it does in the heat of the day. It is about 87 degrees outside even now and about 90% humidity.
Lots of pics, but I wanted to show the install. I still have to tape it all up tomorrow. I will not be paneling right away and putting the front on as I have to build all the walls still. Tomorrow I will get the Refrigerator installed below the AC. The pics do not show it, but the AC is fastened to the shelf with "L" brackets I made. The screws already existing in the AC cover hold them on and then I screwed the other side into the shelf.
The sweet thing about this AC, and my primary reason for doing the AC this way instead of the roof mount, is that it will run off my Honda 2000 generator and cool the trailer very well with enough juice left over to run other things and charge the batteries if needed.
Your AC install and vent setup looks good Don. Its pretty much what I've thought about doing on my install. Keep up the good work.
Martin
