I agree, not a foamie failure.
I do disagree with the bolt recommendation to a certain degree. Serrated washer faced bolts and nuts are good for quick assembly in a commercial production line environment, but may not be the best use in every application. Especially where not clamping two rigid items, such as thru HSS tubing or the configuration that Mike showed above passing thru two portions of a bracket that can crush and yield with no anti-crush sleeve. Once they loosen up the nut can still rattle off, just like a plain nut and split lock washer or no lock washer at all. Nylon insert locking nuts are better in this regard since they won't rattle off, but they cost more and are more effort to install with dedicated flat washers.
Also, grade 5 hardware should be fine, for properly engineered joints, for most trailer chassis applications except maybe the suspension components. Not understanding the factors that go into engineering a fastened joint and automatically assuming that Gr 8 will fix all problems is uninformed thinking.
I, too, don't like how the A-frame member rides outside the bracket loop; and the tongue member appears to have been cut down to a single side of the structural shape, or just a flat tab. I wondered if this was just a result of the roadside repair, being too difficult to get the member back into the bracket, but then it seems like it is part of the folding tongue design.
Thankfully there was very little damage and no one got hurt.
