Cheap Awning Option
Cheap Awning Option
Postby Rod S » Wed Apr 01, 2015 12:06 pm
I was wanting to attach a awning to my cargo/camper without drilling holes or breaking the seal in the roof cap. I tried some of the figure of 8 awning channel and it seems like it is going to work OK. My trailer is a Wells Cargo and it has a small gutter rail of about 1/4 inch. The figure 8 slide right over it and I can slide my awning in the opposite side open channel. I haven't got to camp test it out yet but the channel attached to gutter seems plenty solid to me. I'm just sewing a small diameter rope in a light tarp to slide into the channel. I have under 18 bucks in the channel delivered so thought I would throw this out there in case anyone is considering a cheap awning option for their trailer.
Rod S
Re: Cheap Awning Option
Postby Rocky5000100 » Wed Apr 01, 2015 12:27 pm
Very nice. Please post pics of the full setup when it's all done!
Rocky5000100
Postby tnriverluver » Wed Apr 01, 2015 6:50 pm
Terrible idea if you want to keep that gutter. Wind or ran load will snap that right off.
tnriverluver
Postby Rod S » Wed Apr 01, 2015 11:24 pm
tnriverluver wrote:Terrible idea if you want to keep that gutter. Wind or ran load will snap that right off.
You could be right, but I don't think it will. It sure seems a lot stronger than what I have used in the past that worked fairly well. This is only a 5x8 trailer and if the tarp is angled and put up right I'm not worried about water at all. Wind on the other hand can do some strange things that's for sure. I wouldn't bet on strong enough winds doing a lot of things. If I think the wind is going to be strong enough to rip things off I will take it off like I would any other awning. I'll tell you what tnriverluver, if it gets torn off I will come on here and tell you it did, and I will thank you for giving me the advanced warning. :beer:
Rod S
Postby dustboy » Thu Apr 02, 2015 9:39 pm
Looks good to me, easy on, easy off. I'd like to see how the whole awning shapes up.
dustboy
Images: 10
Postby backstrap bandit » Fri Apr 03, 2015 5:11 am
Why not just take off the drip rail and screw an awning rail there they make one that basically acts as a drip rail too just google awning rail all kinds of configurations good luck
backstrap bandit
Images: 15
Postby dales133 » Fri Apr 03, 2015 8:28 am
What you want is a sail extrusion.its like what you've got but single sided with varying leg configurations to rivet to your trailer
dales133
Postby backstrap bandit » Sat Apr 04, 2015 7:04 am
That's where I saw them sailrite
backstrap bandit
Images: 15
Postby Rod S » Wed Apr 08, 2015 5:58 pm
If the figure 8 doesn't work like I want my plan B is the awning rail that bolts on. I was trying to get a simple on and off awning and not breaking the seal it has now on the cap. Nice to have a back up plan though. Thanks for the replies. :thumbsup:
Rod S
Postby JaggedEdges » Wed Apr 08, 2015 7:36 pm
Just had an idea, might take some massaging...
Super cheap awning rail for sorta holding a sorta awning to your sorta camper... grab ye one or two of those expandable curtain rods, and a 1/16 drill... pry them open a bit, maybe need to take end caps off that are there to stop them spreading. Get some brads and a brad/pin driver, hold rod onto surface by favorite method, clamps, tape, wife, drill a hole, mash brad into it, pin other end same, then go about every 3" down it... Hopefully you've used some nice round headed brads so you've mashed them pretty smooth. This stuff will probably rust, so use favorite avoidance method, paint, grease, wife. Then you can insert sorta awning...
You might wanna rub the sharp off the edges, don't know how sharp you'll find them.
I'd say this would be goodish for shortish awnings. Probably most acceptable for "gasketing" a framed canopy, tent etc, that has it's own structure so it's not loaded too bad.
Now if you wanted an excuse to put an inch square hoop of beech all round your drop, you could use a router with a dovetail cutter to put a slot in it, then round out bottom with ball cutter, then treat that with linseed oil or something.
Jack of all trades, Doctor of rocket surgery and fellow of the noble college of shadetree meddlers. "in argentum tenax vinculum speramus"
JaggedEdges
Postby Hader » Fri Jul 22, 2016 4:57 am
Rod,
Any update on the awning hack and if it worked for you?
Hader
Images: 84
Postby McDave » Fri Jul 22, 2016 6:33 am
Here's something...
http://www.wayfair.com/12ft.-W-x-10ft.- ... K1013.html
PDF right here..
https://secure.img1.wfrcdn.com/docresou ... 274736.pdf.
and this...
http://www.wayfair.com/10ft.-W-x-8ft.-D ... K1017.html
It seems a lot more reasonable than the Carefree or dometic types. Quality and performance for our purposes is unknown at this time, however, this could be a great start. Some mods and field engineering are inevitable. The price seems right.
McDave
PS. It says "Free Shipping", the shipping alone on a carefree unit is more than the price of this one . Just sayin'.....
McDave
Images: 412
Postby Hader » Fri Jul 22, 2016 11:51 am
[quote="McDave"]Here's something...
PDF right here..
and this...
Thanks McDave. The prices seem very reasonable.
Hader
Images: 84
Postby lrrowe » Mon Aug 29, 2016 12:00 pm
McDave wrote:Here's something...
PDF right here..
and this...
McDave
I just came across this post again and found the timing very good as I am shopping for an awning.
I wonder how it mounts to a CT and how it sets up. Has anyone had any experience with them? The manifacturer's website is weak with information.
Bob
lrrowe
Images: 439
Postby Charly » Fri Feb 16, 2018 2:30 am
Charly
Users browsing this forum: Bing [Bot] and 5 guests
