A 12 ft. FEATHERLITE conversion
Re: A 12 ft. FEATHERLITE conversion
Postby Prem » Wed Mar 16, 2016 3:19 pm
Wouldn't you like to just pull in to a city park, set up next to a pond in the middle of a walkway, camp there all weekend, play volleyball and fish? :lol: Ain't no truth in advertising. :no:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby Gonefishin » Wed Mar 16, 2016 3:31 pm
Heck, I pull into the state park river access, set up next to the river on the edge of the walkway, camp there all week, use the flush toilets and running water, and often fly fish within sight of my trailer! Free. And that's the truth :lol: Image
Gonefishin
Images: 119
Postby Prem » Wed Mar 16, 2016 8:56 pm
Jim,
Glad to see that you're still here on the forum and haven't been driven away by that nasty ______ after all! You're respected here.
Love your photo!
Prem
My goal...
Prem
Images: 144
Postby Prem » Wed Mar 23, 2016 10:48 am
:roll: Should have left it on the trailer! :roll:
https://www.youtube.com/watch?v=87pkn2APTOU
My goal...
Prem
Images: 144
Postby Prem » Mon May 09, 2016 10:24 am
8) Image
Maybe I'll get a vinyl wrap for my cargo trailer to make it look like this! Awesome Santa Fe Chief! :beer:
My goal...
Prem
Images: 144
Postby OverTheTopCargoTrailer » Wed May 11, 2016 2:40 pm
Prem wrote:Jim,
Love your photo!
Prem
Hey stop talking smack about NASTY______________ :lol: :lol:
Postby Ron Dickey » Thu May 12, 2016 9:38 pm
although this seemed to start as featherlite conversion things seem to get bigger and bigger.
Might as well put in this unit it is feather lite hollow inside.
https://www.google.com/search?q=decolin ... BpsQsAQIIg
I have been in it and have my own shots of it. It was up for sale at the time.
Ron
121377......134179
Ron Dickey
Images: 711
Postby McDave » Thu May 12, 2016 11:26 pm
At the other end of the spectrum....
141605
McDave
McDave
Images: 412
Postby warnmar10 » Fri May 13, 2016 8:02 am
bump
"When a true genius appears in the world, you may know him by this sign, that the dunces are all in confederacy against him." - Jonathan Swift
warnmar10
Postby Prem » Sun Jul 24, 2016 6:16 pm
8) If anyone gets a Featherlite and wants to chat, post it here.
Thanks for the nudge Ed. :beer:
My goal...
Prem
Images: 144
Postby Hader » Sun Jul 24, 2016 7:11 pm
I don't have a 'Featherlite' but, as read more to help with my build, I sure enjoy your 'Chats'. You always have something interesting to say. :thumbsup: :beer:
Hader
Images: 84
Postby EZDog » Sun Jul 24, 2016 7:17 pm
Prem wrote:8) If anyone gets a Featherlite and wants to chat, post it here.
Well I am in of course!
I yanked a panel off inside and the wall is made of U shaped channels and it will be impossible to insulate completely with sheets of the hard foam it seems to me?
The construction is pretty impressive but also complicates things a little with trying to get it insulated enough to control condensation when needed.
So it looks like I will be getting estimates for spraying foam after I decide what I want to do for windows.
I also didn't realize that the exterior walls were Screw-less mostly and this makes me lean even more towards narrow windows like you have installed as I don't want to create any issues trying to cut studs and install new framing for bigger windows?
So much fun but so little time to Play!
EZDog
Postby Prem » Sun Jul 24, 2016 8:17 pm
Thanks Hader and EZ.
On the insulation issue. I had found some synthetic wool door, storm door insulation tape that I used on all the uprights (U-shaped, aluminum studs) prior to insulating and paneling with birch ply. That isolated (somewhat) the condensation problem where there was no foam insulation. Only the rivets now get condensation. They're aluminum into aluminum so there's no rust. In lieu of hard-to-find, synthetic wool weather stripping, I'd use "camper tape." (That's the stuff that you put on the bed rails of a pickup truck prior to mounting a canopy.) Maybe two layers. That synthetic wool, storm door, insulation tape was a perfect fit and had just the right density to not compress much. And P.S. Consider doing the under side also. It beats having to use layers of carpet on the inside during the cold season.
8)
My goal...
Prem
Images: 144
Postby EZDog » Sun Jul 24, 2016 8:37 pm
Prem wrote:Thanks Hader and EZ.
On the insulation issue. I had found some synthetic wool door insulation tape that I used on all the uprights (U-shaped, aluminum studs) prior to insulating and paneling with birch ply. That isolated (somewhat) the condensation problem where there was no foam insulation. Only the rivets now get condensation. They're aluminum into aluminum so there's no rust. In lieu of hard-to-find, synthetic wool weather stripping, I'd use "camper tape." (That's the stuff that you put on the bed rails of a pickup truck prior to mounting a canopy.) May two layers.
8)
The problem is with the U chanel but I am thinking the foam sheets will slide under one side in each space but not the other?
I wonder if I can't just apply spray foam inside the channel on one side where the foam sheet won't go and then snap the panels into the other sides channel where it should slide and get what I need that way?
I also used that Rubber Spray paint in my steel CT to isolate the steel studs somewhat from the backside ad I could sure do the same behind foam panels to isolate the Aluminum skin from the panels some.
I wonder if I might be making too big a deal out of this too but this is the sort of problem that only really pops up at extreme temperature swings too and is pretty annoying when it does.
Also you are right,thioe resin soaked OSB panels they use are crazy heavy but also crazy tough and I am not sure yet if I want to give that up for the weight,I do plan on using the trailer to haul stuff when needed.
EZDog
Postby Prem » Sun Jul 24, 2016 8:40 pm
Sounds good. As for the doubts......I wish I had spray foamed it. :( Heat and cold, not just for winter.
My goal...
Prem
Images: 144
