Can the grey vent just be from the sink drain like a residential system or does it need to come from the tank itself?
If it comes from the tank do I need one at the sink as well?
Iconfabul8 wrote:Air Admittance valves Won't work on a tank system. Like MtnDon says air has to be able to escape the tank as water goes in.
flboy wrote:Why don't you just use an Air Admittance valve under the sink or where ever your closet point in the drain line system is near the Gray Water tanks (after all the the traps). My understanding is that these valves are one way and will pull air when the tank is drained, but not vent the tank into the living area. I am going to give this a try on my system as I really do not want to run another vent through the ceiling. The vent I bought does not look like this one, but it gives you a general idea of what they look like.
I would place the vent just after the P Trap.MtnDon wrote:The water / air still has to pass through the p-trap. Gurgle, gurgle, or at worst nothing moves at all.
