First of all, even tho I've been a member here for more'n 10yrs, a lot of the terms are still mysteries to me...
Foamie - trailer of which the 'body/cabin' is built mostly of foam (probably high density styrofoam) which is covered by fabric and/or fiberglass cloth which is then covered by epoxy resin of some type or other. I ain't a foamie fan so don't know the details of this.
Standie - Usually a tiny travel trailer which has room inside to stand, as opposed to a teardrop which doesn't have standing room. A few teardrop designs have standing room when 'erected' such as the winter warrior & perhaps another or two. The standies usually have a galley (Kitchen) inside if at all, whereas a teardrop has exterior galley at the rear, usually under a hatch.
Purpose of wrapping in canvas - Again, I'm not a fan of this but I believe it is for strength as most of the canvas wrapping I'm familiar with is on 'woodies' & is covered with epoxy or fiberglassed in some way??
Many (if not most) tears are built on 4x8' trailer chassis. In the last several years many 5x8' trailers have become available & lotsa folks are using them. Also, many of the original 1930s, 40s, & 50s TDs were built on 4x8' chassis with large, 15"/16" wheels/tires, and with sculptured/flowing fenders alongside, and many builders try to emulate that look. Another thing, many builders distrust the smaller, 12" wheels/tires that come standard on most 4x8' trailers. With the weight of most TDs, & with modern materials of which the axles, hubs, spindles, & bearings are mfg'd, I personally believe this is a non-starter & of little concern, given normal preventive maintenance. I built my 5 wide by 114" long, 48" high TD on a 4x8' Harbor Freight trailer with 12" wheels. We've towed the TD around 30K miles in 10yrs, at all highway speeds, over every kind of road (& sometimes no road at all) with no problems I can attribute to the 12" wheels. The cabin extends over each side of the chassis by approx 6" and 10-12" at front & 2-3" at the rear. I modified the tongue & shifted the axle toward the rear slightly, to provide better towing dynamics & esthetics. I used the factory supplied wheels/tires & thus only had to construct interior wheel wells approx 1" high which intrude minimally when covered by the 4" memory foam mattress & the 1.5" 'eggcrate' topper on that.
Whether or not a roof vent is a must is a personal choice. Since most TDs aren't air conditioned, a method of ventilation is a definite requirement, if only to prevent condensation in cooler weather. I elected to install a Fantastic Fan vent in the roof of my TD, along with windows in both doors. With the windows open slightly & the Fantastic Fan on exhaust, it draws in outside air & the window curtains deflect the air downward toward the bed & it's almost like having air conditioning, even in hot, humid conditions. I did purchase a 'Pet Cool' 2500 BTU external AC & 'plumbed' my TD for it. In more'n 10yrs I think we've used it no more than 6-7 nights here in Arkansas & points south, & we've used the TD a lot! That's a good testament to the efficiency of the Fantastic Fan roof vent. A 'con' might be that you must have a 12v source of power for the Fantastic Fan when camping 'off grid' but most TDs have a battery anyway. Much of our camping has been in 'out of the way' places where we don't have electrical hook-ups. When constructing our TD I installed a 'cheap' converter for 12v power, & for charging the deep cycle battery when we do have hook-ups. Otherwise the tow vehicle charges the battery while driving down the highway.
Hope this is of value to you.
