[img][/img
Larry8 wrote:Starting a new build July 2016 from a NT 5x8 trailer. Here are some of my mods. I bolted on adapters for the 12 inch wheels to 15 inch 6x5.5 mag wheels. This raised the trailer so I mounted the axle above the springs and the hitch mod lowers the hitch 2 inches so it all leveled out. Then I made brackets to mount shocks/dampeners. Next, I'll work on an insulated sandwich floor.
[img][/img[img][/img
[img]
/img]
Larry8 wrote:Hi Tim,
I was hoping that the Teardrop Build would cover the axle enough to keep bris and water out. Maybe it's wishful thinking, great stuff is hard for me to control as it foams up so I would have to trim it. That exposes the inside of the foam and may soak up water. Let me know if you come up with a better solution. I may have to lear to weld and box in the axle.
Larry
Users browsing this forum: Google [Bot] and 14 guests
