Propane
Important Information and Stickies...
(Threads with essential information about building teardrops)
Propane
Postby kdbstlrfan » Fri Aug 19, 2016 8:53 pm
I want to mount a propane tank on the front of my TD and run a line to the back where the stove/oven will be. Has anyone done this? If so, what did you use to run the line to the back? Where did you run the line? Thanks in advance for your help.
kdbstlrfan
Re: Propane
Postby Redneck Teepee » Sat Aug 20, 2016 12:57 am
Use 1/2" black pipe, hold it as tight as you can to the bottom of the frame, flex to your tank and stove off the ends. :D
Redneck Teepee
Images: 21
Re: Propane
Postby kdbstlrfan » Sat Aug 20, 2016 8:56 am
That is what I was thinking but was not sure if there was an easier or less expensive way. Thanks for the assist!!
kdbstlrfan
Re: Propane
Postby dmdc411 » Sat Aug 20, 2016 12:13 pm
I agree with black iron, but it's hard to get exact lengths to work and I don't have the tools to cut and thread pipe anymore. How about soft copper? Flaring tool is relatively cheap. It's easy, and could run black pipe at the ends to the flexible connection.
dmdc411
Re: Propane
Postby greygoos » Sat Aug 20, 2016 12:50 pm
Home D will cut and thread any size pipe for you. When I built food service trailers we ran black pipe for most of the way and adapted to copper tubing to finish. We also ran the pipe inside the trailers, pretty was not an option. I know people do it but be aware that running the gas line under the trailer it is exposed and wide open to debris and corrosion. I personally would never use a 5 gallon tank on a small trailer. The trailer is rocking and rolling down the road and fittings come loose.
truck explosion.jpg (101.28 KiB) Viewed 8446 times
greygoos
Re: Propane
Postby Redneck Teepee » Sat Aug 20, 2016 4:14 pm
greygoos wrote:Home D will cut and thread any size pipe for you. When I built food service trailers we ran black pipe for most of the way and adapted to copper tubing to finish. We also ran the pipe inside the trailers, pretty was not an option. I know people do it but be aware that running the gas line under the trailer it is exposed and wide open to debris and corrosion. I personally would never use a 5 gallon tank on a small trailer. The trailer is rocking and rolling down the road and fittings come loose.
Debris big enough to destroy a 1/2" schedule 40 pipe has probably already destroyed your trailer, corrosion? if you plan on living and using your trailer a couple hundred years...maybe.
Redneck Teepee
Images: 21
Re: Propane
Postby Gladtobehere » Mon Aug 22, 2016 7:47 am
I would use a 5 lb propane tank at the rear and use a flex hose to connect just like the backyard bbq. Perhaps put a water tank on the front and plumb the water.
Gladtobehere
Re: Propane
Postby Shadow Catcher » Mon Aug 22, 2016 8:32 pm
Our tear came with 1/2 black iron and they dropped it below the axle (just waiting to catch a rock). I redid it with 1/2" ductile copper, flexible and easier to run. I do a periodic leak check on all of the joint. and fittings.
Re: Propane
Postby KCStudly » Thu Sep 15, 2016 12:49 pm
I would not use copper for gas line on a moveable flexing vehicle. Copper tubing, although dead soft and flexible, will work harden and become brittle with repeated vibration/flexing.
Take a look at noseoil's Tuscon Tortoise build. He did a very nice installation using black iron pipe, all well thought out with debris guards, proper anchors, flex hose connections at either end, and more.
Re: Propane
Postby GuitarPhotog » Thu Sep 15, 2016 1:57 pm
I would suggest that you put the regulator at the tank end of what ever kind of pipe you use. Otherwise you have a pipe full of high-pressure propane to vent every time you need to remove the tank or the regulator. I find that even the 6ft high-pressure hose between the tank and my Coleman stove holds more propane than I'm comfortable wasting.
<Chas>
:beer:
GuitarPhotog
Images: 55
Re: Propane
Postby Padilen » Thu Sep 15, 2016 7:20 pm
Every trailer I've torn down has had copper. Copper from tank to regulator. (Some had black rubber hoses) Copper from regulator to ...Some- not all, have had a length of black iron under trailer. Some ran through frame cross rails. Black then back to copper. A copper tee or larger connector then all copper. None had multiple runs off black, no tees just one straight piece to copper fitting. If and when I get to propane I'm thinking of hoses with quick connects
Padilen
Re: Propane
Postby MtnDon » Thu Sep 15, 2016 8:29 pm
We owned a 1983 GMC Class C RV for 2 decades; factory equipped with copper lines from the built in ASME propane tank to all appliances. I never did have any problems or leaks. All connections used flared fittings. Similarly some folks worry about using solid core electrical wiring. All the 120 VAC wiring in that Class C was Romexsolid. The only electrical issues had nothing to do with the wires themselves.
MtnDon
Images: 24
Re: Propane
Postby caseydog » Sat Oct 01, 2016 12:34 am
Propane is heavier than air, while natural gas is lighter than air. So, it seems to me that you would want your propane lines under your camper, and not inside your camper -- as much as possible.
Polyethylene propane lines are approved for use underground, where corrosion is a huge problem. Polyethylene tubing is also very flexible. I have not researched Polyethylene tubing for camper use, because I've never had a reason to. But, you might want to research it. It may or may not be the answer, but it can't hurt to check it out.
CD
caseydog
Images: 515
Return to Essential Information about building teardrops
