I seem to think I read somewhere three yrs ago when I got my little camper that one should unplug the trailer from the tow vehicle when camped to avoid also running down the vehicle battery if the trailer battery gets low.
This true or bogus?
Crabapple wrote:Yep reading 12.96V with engine off. Although my devices are supposed to cut out b4 draining either battery too much, I think I will continue to unplug the trailer while camped!
lrrowe wrote:I might be a little confused on this one. If you do not have anything on the trailer draining or drawing power, then why bother with unplugging, that is if you are not removing the trailer from the TV.
If all your trailer lights (call them off grid lights i.e., reading lights, pumps, USB usage and so forth)'are drawing 12v from the TD/CT's house batteries, then again, there is no drain on the TV's battery.
H.A. wrote:lrrowe wrote:I might be a little confused on this one. If you do not have anything on the trailer draining or drawing power, then why bother with unplugging, that is if you are not removing the trailer from the TV.
For the above scenario, short term.
Nothing detrimental occurs leaving both batteries connected.
Just dont park the car & leave them plugged together days on end.
