by artquixotic » Sun Sep 04, 2016 12:29 pm
I didn't take many photos again. Apologies.
The trailer was still in the garage while it rained yesterday. I pulled it out later when it was sunny. As you can see in the photo, it's a little messy and cramped in there.
I actually managed to hang the rear hatch. It's pretty heavy even though it isn't finished, so that was difficult alone. The screws through the hinge into the door were too long and bound up the door, even though I had taped brad shafts to the top seam to keep the gap perfect. So I pulled those out and used the leftover screws from the door kits. I've only got about 1/3 of the screws in, but everything works well. So I'm pretty confident the door will be solid with all the screws in once I buy some shorter ones. The gap for the weather seal is good enough but not as tight as I'd like. Maybe paint, etc. will fill that up. For what it's worth, two layers of rubber will cover the hinge.
I cut the rubber front roof coating down to the final size and glued that down. I had sanded it with 100 grit on the power sander first to make sure it stuck well. Then I stacked sandbags and lumber on top to get it to flatten as much as possible. The rubber needs to be in place before I put the plexiglass down, because the plexiglass will sandwich the rubber down. So I need to get the rear roof rubber installed soon. Meanwhile, I installed the now-finished roof rafters and pounded them flush with a rubber hammer. I filled the little gaps around them with wood filler.
Jumping ahead, I also cut out the plexiglass to the final dimensions and pre-drilled all of the oversized installation holes. I also pre-drilled the holes into the lumber that I had installed earlier in the day. The white plastic coating is still on the plexiglass, which is good, because I've been moving it back and forth a lot to prepare the mating surfaces, drill holes, etc.
I planed down the lumber that framed out the hatch hinge that stuck out above the roof line due to the funky angle. There was a hideous gap in the roof above the rear hatch, so I covered that from the inside with plywood, filled it with insulation, and capped it off with wood filler. Not pretty, but I think it'll do after being smoothed out and covered in topside paint and rubber. I filled a bunch of screw holes and seams on the back hatch too, after I'd applied more plywood to it. I've been using brads lately (in combination with lots of glue, of course), so I've been filling those holes too.
I drilled a hole through the diamond plate all the way into the cabin behind the sink drain hole. Then I pushed some wire through that will power a little LED license plate light I ordered while eating lunch. The license plate will cover the drain up, at least when viewed from the rear.
- Attachments
- trailer_hinge_spacers.jpg (25.35 KiB) Viewed 1670 times
- trailer_in_garage_hatchless.jpg (34.34 KiB) Viewed 1670 times
