Design Library - we need your files...
Threads about the forum, forum software, forum features, etc
Re: Design Library - we need your files...
Postby mikeschn » Fri Aug 26, 2016 4:24 pm
dmdc411 wrote:I found a whole boat load of copies I made from the library. All on a 5G stick. How can I send it all in a post? Email??
Does it include stuff not posted here: http://tnttt.com/Design_Library/Design_Library.html
Postby dmdc411 » Fri Aug 26, 2016 6:36 pm
I haven't had time to go through either to see what I have. But think I copied most anything that pertains to teardrops.
dmdc411
Postby Ron Dickey » Sun Aug 28, 2016 10:11 pm
under Wiley windows he did sever in several sites
viewtopic.php?t=51721&p=953331
has anyone tried contacting member in uk and see what they know?
173882......173887
Ron Dickey
Images: 787
Postby Breytie » Sun Aug 28, 2016 11:52 pm
I have looked at the resurrected site and it looks quite different from the original. A lot of links point to the wayback machine cached files and not local files so you have no control over them.
The files I have are the original source files - not "save page as".
The only thing I see missing from my files, are the "All Wood".
I am unable to attach the whole site as a single RAR, so I will break it up into bite sized chunks and post it over the next day or 2. Just dump all the files into the server folder and point the referring page to index or tear00 and it will work. All links are relative so no editing will be required.
Experience is learning from your own mistakes
Here I make mine in public: My build
Breytie
Images: 36
Postby Ron Dickey » Tue Aug 30, 2016 10:56 pm
His personal album has quite a lot plus some pictures of him.
I researched his name was he a designer before this too. There are a lot of folks with his name. :thinking:
173882......173887
Ron Dickey
Images: 787
Postby Breytie » Wed Aug 31, 2016 2:06 am
What the?
Earlier I tried to upload the whole lot as one RAR and everything timed out.
Broke it down to 5 to 6 MB RAR parts, it came up with:
The attachment’s file size is too large, the maximum upload size is 2 MB.
Please note this is set in php.ini and cannot be overridden.
I broke it down to 2MB chunks, retried and now it said:
The file is too big, maximum allowed size is 1 MiB.
That will make for a lot of pieces!
Any ideas?
Breytie
Images: 36
Postby Breytie » Wed Aug 31, 2016 2:17 am
Giving up - this is going to take ages - message:
Cannot add another attachment, 3 is the maximum.
That is when I have to send a total of 30 pieces.
Removed attachments.
I need another idea
Breytie
Images: 36
Postby Ron Dickey » Wed Aug 31, 2016 9:01 pm
I know there are folks in our forum who have more ideas then I and have better ideas. Not fully knowing what I am saying but having a Photographic background.
Can you group them
In my computer I can take a shot put it next to a group of other shots and then copy them as a collage then send them.
I have a friend who uses
https://www.hightail.com/
to send higher bit peaces.
and if you and say mike had this maybe it would get put up over time.
People like SDTrippers2 might like doing things that. He did the General Alphabetical INDEX Information for the forum.
I know how each step is asking more then perhaps is needed and there must be a way around it.
One mans work can be an norther's burden.
Thank you for doing what you do. :thumbsup:
Ron
173882......173887
Ron Dickey
Images: 787
Postby dmdc411 » Wed Sep 07, 2016 10:19 am
I found a few, but I am having a hard time attaching the files. Bear with me as I fumble through this! The file size is 2677kb. I keep getting this Fault; The attachment’s file size is too large, the maximum upload size is 2 MB. Please note this is set in php.ini and cannot be overridden. I even zipped it, and it's not much smaller. It is a PDF file if that helps anyone! I'm not a computer goo roo, but do ok on my own.
dmdc411
Postby working on it » Thu Feb 09, 2017 12:32 pm
I don't know if I was not opening the files correctly (in the restored design library), but here are two excel worksheets, that I either couldn't open, or were damaged and didn't open just for me. I found them in my 400MB of stored planning files.
IVA Drawbar Strength.xlsx
(25.97 KiB) Downloaded 422 times
balance(template).xls
(599.93 KiB) Downloaded 443 times
173193172890148599
working on it
Images: 457
Return to Threads about the forum!
