Ideas, please....
Ideas, please....
Postby DirtyD1833 » Sat Sep 17, 2016 5:40 pm
Building my bed, how do you guys fasten this to the wall?
DirtyD1833
Re: Ideas, please....
Postby KennethW » Sat Sep 17, 2016 6:05 pm
I would go with two good short ratchet straps that would stay on the wall and hook midway down on the bottom of the bed. Fast easy and low cost.
Just a thought. How about a fold down counter(galley)on the bottom of the bed with the galley supply between the bed supports.
KennethW
Images: 82
Postby Alan_H » Sat Sep 17, 2016 7:47 pm
I was thinking ratchet straps as well.
How much weight do you plan on having on that bed? I think it would be plenty with about half of those cross-braces, and a lot lighter to lift when stowing.
Alan_H
Postby DirtyD1833 » Sat Sep 17, 2016 8:38 pm
I tend to "overbuild" but you are probably right about the cross braces. So how should I go about fastening the straps to the wall?
DirtyD1833
Postby KennethW » Sun Sep 18, 2016 11:14 am
DirtyD1833 wrote:I tend to "overbuild" but you are probably right about the cross braces. So how should I go about fastening the straps to the wall?
Mount a small D ring to the wall studs.
KennethW
Images: 82
Postby DirtyD1833 » Sun Sep 18, 2016 12:07 pm
I underestimated the thickness of my walls, just screwed the small d rings in and done!
DirtyD1833
