We have connection! The galley is glued and screwed to the floor and back wall.
![Image](http://uploads.tapatalk-cdn.com/20160916/b6364f4f551538635b3799769ecdbb45.jpg)
Door side shot. Pretty even and level in a very loose TLAR way. There is a gap between the two walls. I'm going to try using the low volume GStuff and fill inbetween later.
![Image](http://uploads.tapatalk-cdn.com/20160916/4570528f3d29154198cae8c36a898935.jpg)
Driver's side shot. Less even but still pretty level. Filled in the gap with small wedges of foam. Spackle and GStuff will finish the rest.
![Image](http://uploads.tapatalk-cdn.com/20160916/cd61d9bfcef5826223a7a3d5f3c8dbb2.jpg)
Close shot of the foam filler. It is sitting in the adhesive for the floor, so I'm sure it will stay put.
![Image](http://uploads.tapatalk-cdn.com/20160916/76128d42f19c2f7bd3a103b2893e14f7.jpg)
I had hoped to use the hatch like the simple foamie, but it's lifted height would have been right at 5'. A head knocked even for me
![](http://emoji.tapatalk-cdn.com/emoji851.png)
,so I went with galley doors. I'm using only one door to stabilize the back, just in case anyone is wondering.
