San Diego Lightweight Toy Hauler / Man Cave
Re: San Diego Lightweight Toy Hauler / Man Cave
Postby flboy » Tue Sep 20, 2016 7:25 pm
PaulzOx wrote:Look at what showed up today!
Trim pieces... Time to make my trailer look sexy
PaulzOx
Very nice. Are those Aluminum or the PVC (faux) type? I'd like to use that also on the floorline but it gets pricey quick.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby PaulzOx » Wed Sep 21, 2016 12:06 am
Don,
They are aluminum. The price was not to bad, got them for $115. It is still a good amount of money though. But I really wanted diamond plate trim.
Here are a couple of low quality pics (got dark) of what I got done today.
Before:
After:
PaulzOx
PaulzOx
Postby McDave » Wed Sep 21, 2016 2:23 am
Well now, those ARE Sexy. That's a lot of impact visually for 100 bucks. I'm impressed...Supplier?
McDave
McDave
Images: 412
Postby PaulzOx » Wed Sep 21, 2016 7:37 am
McDave wrote:Well now, those ARE Sexy. That's a lot of impact visually for 100 bucks. I'm impressed...Supplier?
McDave
Dave,
I googled diamond plate crown molding and found this site https://www.tread-ware.com/Catalog?cate ... wn_Molding I thought the prices were reasonable so I got them there. There might be other sites with cheaper prices.
PaulzOx
PaulzOx
Postby flboy » Wed Sep 21, 2016 8:16 am
Thanks Paul. They have great prices from what I can see. I may reconsider and go with the diamond plate trim. Yours looks great.
Sent from my SM-N900P using Tapatalk
Don (Flboy)
flboy
Images: 378
Postby Id10t » Wed Sep 21, 2016 8:21 am
McDave
Dave,
PaulzOx
Thanks for that link. Their pricing is great compared to what the trailer companies want for upgrades.
Id10t
Postby rebapuck » Wed Sep 21, 2016 9:24 am
Great solution with the cabinet doors. I think you will be happier without the center stile. Having one would make larger items difficult to place inside.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby funengineer » Thu Sep 22, 2016 6:25 pm
Tread-Ware has great prices compared to others. Thanks for the link. If anyone needs larger sizes or custom pieces check out diamondlifegear.com.
Pricey stuff.
Sent from my tractor seat.
funengineer
Postby PaulzOx » Fri Sep 23, 2016 12:32 pm
rebapuck wrote:Great solution with the cabinet doors. I think you will be happier without the center stile. Having one would make larger items difficult to place inside.
Yes I agree, having an open center makes it easier to put larger items in. I am contemplating installing a shelf in there also... Decisions decisions!
PaulzOx
PaulzOx
Postby flboy » Fri Sep 23, 2016 1:04 pm
I am not putting shelfs in my cabinets, but rather I am buying some cheaper stackable bins with drawers from Walmart which can be bought in various sizes. I can then configure and reconfigure as needed or remove altogether if I have need to install a larger item. Just and idea.
Don (Flboy)
flboy
Images: 378
Postby PaulzOx » Sat Sep 24, 2016 11:10 am
flboy wrote:I am not putting shelfs in my cabinets, but rather I am buying some cheaper stackable bins with drawers from Walmart which can be bought in various sizes. I can then configure and reconfigure as needed or remove altogether if I have need to install a larger item. Just and idea.
Thanks for the input, I like your idea. I may have to barrow that one.
PaulzOx
PaulzOx
Postby PaulzOx » Sat Sep 24, 2016 11:13 am
I made more progress on the trim yesterday. I only have to figure out the two pieces for the vee, they have weird angles.
I am going take a break from the angle brain hurt today and start on my beds.
PaulzOx
PaulzOx
Postby McDave » Sat Sep 24, 2016 12:35 pm
McDave
Images: 412
Postby hankaye » Sat Sep 24, 2016 4:24 pm
PaulzOx, Howdy;
Better still, you'll need to do the angles and using the sine and cosine formulas find those.
http://www.calculator.net/triangle-calculator.html
You're a smart guy and I sure you already knew that but it might help someone else latter
on down the line.
If you're like me I just grab the nearest teenager or Millennial and have them do the math
on their "devise". I do know the 3', 4', 5' rule when squaring the corner of a building ... :D
hank
hankaye
Postby PaulzOx » Sat Sep 24, 2016 10:23 pm
Well I did not exactly take a break from the angles but I did figure them out. I first tried the above suggestions and I did get a correct angle then I started BS'ing with my neighbor and he said the orange box store had a cheap angle finder. Since I had to return some unused track anyway, I made a trip. Low and behold...
This little $5 tool made it so simple. I did have to use a little math... Anyway here is how it turned out.
I also made a little progress on my beds as well.
PaulzOx
PaulzOx
