Camp4Life wrote:Nice to see that on the trailer! I'm in the same boat as you, nowhere heated to work indoors. I was also thinking of getting one of those popup car shelters. Looks like we're not gonna see anything over 10 degrees next week in Edmonton....
KCStudly wrote:Bamboo skewers work, too, but sometimes the glue grabs them and they aren't easy to pull out. If that happens just trim flush (or below flush and fill) and abandon them in place.
fotooutdoors wrote:Could you lay the trailer down on a sheet of OSB? Not free, but better than denting up all your hard work.
Sent on my phone. Pardon the autocorrect.
OP827 wrote:Camp4Life wrote:Nice to see that on the trailer! I'm in the same boat as you, nowhere heated to work indoors. I was also thinking of getting one of those popup car shelters. Looks like we're not gonna see anything over 10 degrees next week in Edmonton....
I am also in Edmonton,hi there. I built panels flat and laminated them flat before assembly in my build.
dancam wrote:Thanks guys. I could possibly have built a flat surface and glued the whole roof together and canvassed it, then tried to stick the whole 12ft thing in at once, but it would have been pretty difficult and time consuming with just the 2 of us. I also didnt ask until i had already put almost half the roof in... :/
The only way i can think of doing it now is to lay the trailer on its side. However the side that ends up down will most likely get damaged because we will have to stand in it to canvass the ceiling and we only have a very bumpy lawn that isnt level.
So im not sure what to do. Hoping to canvass this saterday. Where do you buy blow gun darts? Their probably illegal in Canada, lol.
KCStudly wrote:For wood to wood where the joints were backed up by Kreg pocket screws, I've gone as low as 45 deg F (7.2 C) using TB2, but the buzz on the interwebs sez that it will be a weaker joint. When you snap a test joint if it looks white and chalky and doesn't break any wood away, it was too cold. On a good joint the glue will look almost like semi-clear plastic and should take at least some small slivers of wood with it when broken, in my experience. Not very scientific, but these were my observations on the few chances that I observed.
OP827 wrote:dancam wrote:Thanks guys. I could possibly have built a flat surface and glued the whole roof together and canvassed it, then tried to stick the whole 12ft thing in at once, but it would have been pretty difficult and time consuming with just the 2 of us. I also didnt ask until i had already put almost half the roof in... :/
FYI, George has just posted how he's successfully done canvas glueing overhead in his build - http://tnttt.com/memberlist.php?mode=viewprofile&u=9914
ghcoe wrote:I use DAP Alex Plus caulk. Here is a picture of me applying it exactly as you want, on the inside corners.
Camp4Life wrote:OP827 wrote:Camp4Life wrote:Nice to see that on the trailer! I'm in the same boat as you, nowhere heated to work indoors. I was also thinking of getting one of those popup car shelters. Looks like we're not gonna see anything over 10 degrees next week in Edmonton....
Awesome! Never realized there were so many Edmontonians on here!Makes me wonder why there isn't an Alberta section in the forum, only Ontario Quebec and BC...
