TiteBond II gallons needed ?
Postby rustytoolss » Mon Oct 03, 2016 9:39 pm
I'm building a Foamie TTT 9.5'x6'x6'. On average how many gallons of TiteBond II should be needed for the canvas work? I will be using 10 oz canvas on the exterior. And bed sheets (or canvas) on the interior. I'm buying supply's tomorrow . So I could use this information ASAP. Thanks :)
I can get the TirebondII for $15.93 a gallon.
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: TiteBond II gallons needed ?
Postby ghcoe » Mon Oct 03, 2016 9:49 pm
So far I have used nearly 2 gallons on my build. Still have 3 interior walls to do, but I am confident that there is enough glue left for that. I thin my glue 50/50 with water so you might keep that in mind if you plan to use full strength. I also used 2 gallons of gripper and exterior Latex paint. My build is 8'4"x5'4"x4'2". Good luck. :thumbsup:
George.
ghcoe
Postby rustytoolss » Tue Oct 04, 2016 3:35 pm
Thank You, :thumbsup:
rustytoolss
Postby lthomas987 » Mon Oct 10, 2016 2:00 pm
The titebond site recommends only adding 5% water to the glue, and that doing so will cut the viscosity by 1/2 for easier spreading. I can confirm that 5% water does make it spread a lot better. I didn't go any thinner than that. I used just over 2 gallons on my foamy which isn't as big as you're talking but I did the inside, the outside, and all my partitions (Probably another 16-20sq ft of surface) I sanded and peirced my foam, and used linen that was fully wet out but I didn't bother trying to fill the weave or anything nuts like that.
Laura
Bike-Drop a Micro-Foamy Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=59274
My first Superlegarra-ish Foamy build http://www.tnttt.com/viewtopic.php?f=55&t=59049
lthomas987
Images: 204
Users browsing this forum: jgmahoney and 8 guests
