Nookery Updates -- 25 Oct Update. Working on the galley
Re: Nookery Updates -- Sep 28 2016 New Floor is finished
Postby bonnie » Sun Oct 09, 2016 7:36 am
I messed up somehow when I put the wall anchors into the wall. The pair on the left are too close together. I may try and fix it. But I'm running out of time.
Remember, the turtle won. :)
bonnie
Images: 107
Postby GPW » Sun Oct 09, 2016 7:41 am
Nothing you can’t do ( or re-do ) on a Foamie eh !!! :thumbsup: 8) Best do it now before you fill up those shelves... just sayin’ ... :roll:
Postby bonnie » Tue Oct 11, 2016 9:03 pm
I cleaned up the big double window today. To square it up I clamped my 4' level and a board then used my cutoff saw to trim everything level. For bigger areas I used the same clamping method with my skill saw. Came out pretty well.
I also used 1/2" angle to trim out the window on the driver side. It's not glued down, but it covers the edge really well.
Good day. I also got a seasonal job at the local mall. :)
bonnie
Images: 107
Postby GPW » Wed Oct 12, 2016 5:35 am
seasonal job .... Santa’s helper ? ... 8)
Postby KCStudly » Wed Oct 12, 2016 6:31 am
Selling calendars? I need a good calendar. :lol:
But seriously, congratulations on both accounts, the window RO looks good and having a little supplemental income around the holidays is always a good thing. :thumbsup:
Postby bonnie » Wed Oct 12, 2016 6:54 am
No calendars. Ladies retail. Thanks for the encouragement. It means a lot.
bonnie
Images: 107
Postby bonnie » Fri Oct 14, 2016 9:46 pm
Some more progress-- getting the flashing glued in for the cooler bump out:
This one is the wall for the inside of the cabin. I bent the 3x3 flashing opposite of the regular way to make a tube. Waiting for the adhesive to set up.
Side shot showing the flange.
And another piece of 3x3 flashing glued and clamped to the galley side. I wanted to give that area a bit more protection.
My next door neighbor is going to wire me an electrical box much like this one, but GFCI.
Was a good day overall.
bonnie
Images: 107
Postby bonnie » Tue Oct 18, 2016 3:23 am
The cabin is fully enclosed.
I trimmed all the foam bits and the cooler bump out is just about complete. Using Great Stuff to fill holes and glue everything together. If I can get the windows in this week, I could camp, but won't yet. The doors still need done. Onward and upward.
bonnie
Images: 107
Postby GPW » Tue Oct 18, 2016 5:46 am
Wonderful !!! You’ve really made some great progress!!! :thumbsup:
Re: Nookery Updates -- 25 Oct Update. Working on the galley
Postby bonnie » Tue Oct 25, 2016 7:03 pm
Hi! Got a bit more done. I had hoped to find a c-channel type flashing to border the galley doors. I was in Menards today and they had something that fit my plans. One edge would need flattened. So I brought it home and did that just that.
Oh, and I got the second stripe painted on the sides.
bonnie
Images: 107
Postby bonnie » Tue Oct 25, 2016 7:05 pm
I also got a first coat of tan on the galley. No picture as it was too dark for
bonnie
Images: 107
Postby GPW » Wed Oct 26, 2016 5:54 am
Coming right along !!! :thumbsup: 8) Best not make the galley too heavy or you may have to use those pavers to make a brick patio up front ... ( towing) :lol:
Postby bonnie » Wed Oct 26, 2016 6:26 am
Creative packing to offset the galley, plus the AC will be permanently mounted up front.
bonnie
Images: 107
Postby GPW » Thu Oct 27, 2016 7:01 am
Bonnie , I was just being silly , we knew you had the situation well under control !!! :thumbsup: ;)
And , you’ve made a great example of how easy it is to “modify “ a foamie camper to suit your needs ... 8)
Postby bonnie » Thu Oct 27, 2016 7:46 pm
Thanks! :)
bonnie
Images: 107
