felixx wrote:Just make sure you use acl with aluminium on both sides.
I did one side with aluminum only on one side. .
The cladding cracked on that side
greygoos wrote:Bob - Being that you have a sign business can I ask if you have any experience with expanded PVC. Do you think it might be feasible to use as an exterior skin? Thank you and good luck with your build
KCStudly wrote:That looks sweet!
Sheddie wrote:Hi Bob,
welcome from New Zealand.![]()
I see you are planning on using ACM/ACL (whichever you prefer to call it).
I thought you would like to know that I used it for my teardrop, and I am very pleased with it. Cutting and shaping was easy and it curved over the roof with no problem at all. Sides are glued to the ply, my sidewalls are 3/4" ply with holes cut out and polystyrene insulation and 3mm ply on the inside. If I had known then what I know now I would have cut out more of the 3/4" sheet. Over the roof the ACL is glued directly to the cross beams with the polystyrene insulation between the ACL and the inner skin.
I used 4mm acl and had no problem bending it over the curve of the roof and hatch. If you are using 3mm it should be even easier. I used 3m x 1.5m sheets on the sides and a 4.8m (15' 9") x 1.5m (5') for the top which was long enough to do the full length over the roof and hatch. And the best part was that once it was fastened on it was finished. No sanding and painting etc!
I will be interested to see this build progress, all the best with it
