6.5' Popup Build
Re: 6.5' Popup Build
Postby myjeepcherokee » Wed Oct 26, 2016 9:15 am
With the cooler weather starting to make its appearance I'm starting to feel the pressure to get the Popup finished up, I was able to get the plumbing system finished this week. I'm still hopeful that I'll be able to get it out for a weekend trip as I would hate to have to park it for the winter without having had the opportunity to test it out. I'm down to making seat cushions, installing the fold out and top, tongue jack, carpet, touch-ups, and wheel bearings.
myjeepcherokee
Images: 20
Postby kludge » Wed Oct 26, 2016 1:38 pm
Did I miss in the video where you sealed the edges of the exterior skin (masonite/hardboard) ???
I heard you mention it but I never saw you do it or what you did.
kludge
Postby myjeepcherokee » Mon Oct 31, 2016 3:28 pm
Couple things I did to seal it up:
1) Sealed all exposed Masonite edges with 4 coats of lacquire before applying the aluminum siding.
2) I setup step block so that the aluminium siding overhung the masionite by about 1/8" on all the bottom edges, this allowed me to created a channel to which I could run a bead of silicon between the frame and the sides.
3) The vertical joints were sealed with silicon underneath the edge molding. I did get lucky that when I routered the extra aluminum siding off it was an extremely tight joint so the silicon is just insurance.
4) I rolled the aluminum over the top edge.
5) Sealed around all the plumbing / power inlets / lights with butyl tape
My top overhangs the sides by 1" when closed, and 6" when open so the only areas exposed moisture in a rain storm is the very bottom edge, hence the channel created for the silicon sealer. The 1/8" overhang of the aluminum siding also works like those gutter leaf covers - the waters surface tension wants take it off the sharp point away from the Masonite above.
kludge wrote:Did I miss in the video where you sealed the edges of the exterior skin (masonite/hardboard) ???
myjeepcherokee
Images: 20
Postby myjeepcherokee » Mon Nov 21, 2016 8:45 am
It's done!
myjeepcherokee
Images: 20
Postby MadMango » Mon Nov 21, 2016 10:07 am
Wonderful! Congratulations!
MadMango
"Art without engineering is dreaming; Engineering without art is calculating." ~Quentin Stafford-Fraser
You can see my design planning, The Mobile Mango.
You can follow my TTT build here, The Mobile Mango
MadMango
Postby flbikejunkie » Mon Nov 21, 2016 5:35 pm
Nice project and one I've thought about doing myself.
flbikejunkie
Images: 134
Postby S. Heisley » Mon Nov 21, 2016 9:36 pm
Congratulations on your Popup! :thumbsup: :applause:
I've added you to the "...Trailers with Lifting Roofs" thread, near the bottom of the first posting on the first page:
viewtopic.php?f=5&t=50969&p=943454#p943454
Postby bc toys » Sat Jun 03, 2017 9:21 am
how come I can't see any of your Pics
bc toys
Images: 42
