my truck camper
Re: my truck camper
Postby Philip » Mon Oct 31, 2016 6:21 pm
Today I was back on the frame work.
I still need to add a little more cross bracing.
That old project might be gone on Wednesday. If it does then I'll be working every day on this project.
Philip
Images: 323
Re: my truck camper
Postby alchemist77 » Tue Nov 01, 2016 10:24 am
This is really coming along nicely. I like the model, it gives a great sense of perspective and physicality. Thank you for the pictures! It is much easier to comprehend what happens in each discussion. Any idea how much weight the holes save?
Sent from my Lenovo TAB 2 A10-70F using Tapatalk
David Campbell
KF7SFU
RaDAR
SOTA
alchemist77
Images: 10
Re: my truck camper
Postby Philip » Tue Nov 01, 2016 10:43 am
alchemist77 wrote:Any idea how much weight the holes save?
I didn't save as much as you would think. About 1/2 pound a board so 2.5 lbs total. The cross bracing will bring the weight back up. So it was small trade off.
Philip
Images: 323
Re: my truck camper
Postby Philip » Sun Nov 06, 2016 6:30 pm
The old project is gone now. I did some cleaning and rearranged. A few days ago I threw in the cross bracing. Tomorrow I am heading down to the local lumber yard and pickup a bunch of plywood. That's going to hurt. :cry:
Philip
Images: 323
Re: my truck camper
Postby Philip » Mon Nov 07, 2016 7:09 pm
I picked up 10 sheets of 1/4" cabinet grade plywood and 2 sheets of 3/8" A/C ply.
I threw the 3/8" onto the frame. I used GG and 3/4" brads from my trim nailer to fasten it down. Then I grabbed the trim router and a flush cutting bit to remove the excess plywood.
Then when my son showed up we flipped it over for tomorrows follies. :lol:
Philip
Images: 323
Re: my truck camper
Postby KCStudly » Tue Nov 08, 2016 7:25 am
Looking good! :thumbsup:
Re: my truck camper
Postby Philip » Tue Nov 08, 2016 9:30 pm
Today I added some oak blocking to the inside of the frame work at the mounting points. Then I started to do some glass work. I am only running all the corners. Then I'll go back and fill in the fields after the corners are done.
Philip
Images: 323
Re: my truck camper
Postby Philip » Wed Nov 09, 2016 8:16 pm
Did more glass work today not quite half way done. :cry:
Philip
Images: 323
Re: my truck camper
Postby Philip » Thu Nov 10, 2016 11:23 pm
Started on more glass work. Ran out of 2" glass tape. I thought I had ordered two 15 yard rolls. Come to find out I had only ordered one. So had to reorder more. So it might be Monday before it shows up. Coming out of RI won't be fast I bet.
What work I did get done wasn't worth pic's today. Tomorrow guess I go to plan B once I figure out what that is going to be. :lol:
Philip
Images: 323
Re: my truck camper
Postby Philip » Fri Nov 11, 2016 10:12 pm
Plan B went into high gear. I started out with a run to the lumber yard to pick up some type of slick surface 4x8 sheet. Ended up with a 4x8 sheet of bath room masonite. This I will use as a cutting board for glass cloth. Here is a pic about half way threw getting the fields filled in on the glassed side.
Here the fields are filled ready for glass.
This is where I knocked off this evening. I'll finish off those small blocks tomorrow.
Philip
Images: 323
Re: my truck camper
Postby Philip » Sat Nov 12, 2016 5:49 pm
Back to glass work today. I finished off that half of the frame work.
I was surprised today. My order for the 2" glass tape showed up. I also had 10 yards of 50" glass with it.
Need to order more epoxy next week. Went threw about 1/2 gallon so far.
Philip
Images: 323
Re: my truck camper
Postby KCStudly » Sun Nov 13, 2016 2:39 am
You're doing good work there, but I am wondering about the logic of glassing the inside of the panel. Wouldn't it make more sense to just seal and/or skin the outside?
Re: my truck camper
Postby noseoil » Sun Nov 13, 2016 8:18 am
What KC said...
137905
noseoil
Images: 670
Re: my truck camper
Postby Philip » Sun Nov 13, 2016 8:28 am
KCStudly wrote:You're doing good work there, but I am wondering about the logic of glassing the inside of the panel. Wouldn't it make more sense to just seal and/or skin the outside?
What little glass work I have done over the years puts me into the rank ameture class. So I am using the inside of that frame as a practice section. There I can try different techniques to see which give me the best finish. There are going to be some big areas to glass on the outside. I don't want to spend weeks trying to sand out and patch up rough/bad glass work.
If my camera was good enough to take close up pic's I could show you the difference between the first panel and the last one I have done. There is a night and day difference between them. By the time I get that frame done. I will feel better about doing the outer walls.
Philip
Images: 323
Re: my truck camper
Postby Philip » Sun Nov 13, 2016 10:08 am
I had my son come out with his camera and try some pic's.
This is the first panel I did. Its kind of hard to make out. Has to much epoxy. That panel would require a bunch of sanding before any more coats could be put down if it was an exterior panel.
This panel was about #7 or so. This panel would take about 1 minute or less with a D/A sander and its ready for another coat.
My first exterior panel is going to be 48x96 lay up. I would have been very depressed with the results of the first panel I did.
I do need the practice. :lol:
Philip
Images: 323
