by gudmund » Sun Nov 06, 2016 11:28 pm
the Handy Heater and the Lasko heater are both hot air heaters and are both very QUITE being they are very low wattage heaters and do not need that strong of a fan to operate. I have also found they both work great for just warming up the trailer some time before bed time and when getting in side for bedtime I usually end up shutting it off being my body heat and breathing seem to keep things warm enough when sleeping in such a small place, even it I need to turn it on for some heat, it is not that loud. Now when I first tried using a regular sized 1500 watt heater (Cube Heater) - I agree!! it was just too much!! too noisy and just too HOT!!! just plain "in your face" HOT!!!! even when just using it's lowest setting at 600 watts - noisy and hot!! The Lasko is only 200 watts and the Handy Heater is 350 watts with a 2 speed fan - the low speed on it is about as loud as the single speed setting on the Lasko but even on the Handy Heater's high speed, it is not that loud. So far the Handy Heater is checking out fine with it's heat settings and timer system and I am really liking it!!!! I really like it not having a power cord - just plug it into the wall plug-in socket and it stays in place and being my trailer has a center located wall plug-in between my overhead cabinets, it works fine. The Lasko has a power cord and a shelf is needed to set it on when using it, also it has NO thermostat and has to be shut off when warm enough being it just has a on/off switch, but being it is just 200 watts, it never gets that hot. What is also nice about both of these heaters is that neither take up much space and can be stored away out of the way when traveling - so little space that I have had to try and remember where I had put it last when I wanted now to use it. The Handy Heater is 6 inches tall, 3.25 wide and 4 inches deep with the Lasko being actually just a bit smaller but with a power cord!!!
