7x14 trailer - single vs. tandem axle?
Re: 7x14 trailer - single vs. tandem axle?
Postby nitro_mt_racer » Wed Nov 09, 2016 11:09 pm
Diamond Cargo will build you a 7 x 14' vnose single axle. Normally when a manufacturer/dealer is quoting dimensions it's the box size not including the depth of the v.
http://diamondcargo.com/7x14-Single-Axl ... 16828.aspx
nitro_mt_racer
Postby Padilen » Thu Nov 10, 2016 7:52 am
nitro_mt_racer wrote:Normally when a manufacturer/dealer is quoting dimensions it's the box size not including the depth of the v.
Except many dealers! Becks in Michigan is famous for it. If you call around some dealers do.
Padilen
Postby nitro_mt_racer » Thu Nov 10, 2016 10:38 am
Cross Trailers will also build you a 7 x 14' single axle and you can pick it up in Elkhart. I bought mine thru a broker. PM me if you want their info.
nitro_mt_racer
Postby firemansd19 » Mon Mar 13, 2017 8:26 pm
This seems like an older post. But maybe a few of y'all have had time to make decisions on your size. I have recently purchased a 7' X 14' SA w/5200 LBS axle. It also has the 7 way plug w/ trailer brakes. It is a flat (square) nose and has a 6'6" height. My plan is a simple kitchenette in the front 2' and the rest for toys (i.e.: dive gear, atv, and maybe a bed for deer camp.
firemansd19
Postby CoventryKid » Mon Mar 13, 2017 10:11 pm
Zuren:
I tow our NEO 7x16 CT with our Savana high top conversion van. I have no trouble seeing down the sides of the trailer with the OEM mirrors.
There's a Youtuber (Less Junk More Journey) who tows an Airstream with a GMC diesel van. He uses add-on mirrors he got from e-trailer.com to see around the 8' width of the Airstream.
Hope this helps!
Doug
Vancouver Island, BC
GMC Savana Explorer Limited SE hightop conversion van
NEO NAVR 7x16 V-nose aluminum trailer now a comfortable travel trailer
Build: http://www.tusker-international.com/1-trlr-build.html
CoventryKid
Images: 130
