Our first tiny trailer build.
Postby KingAirNeal » Fri Nov 11, 2016 12:31 am
We have been discussing it for years.
A nice teardrop to pull behind the Jetta Sportwagon.
Then VW had to cheat and lie, so we are selling it back.
We bought another Jeep. This time. A Grand Cherokee.
Lots of off roading out here in Vegas.
So an off road capable square back was in order...
And so it started...
KingAirNeal
Re: Our first tiny trailer build.
Postby KCStudly » Fri Nov 11, 2016 7:27 am
Welcome! It is always good to have a plan, and yours looks to be well thought out. Good luck with your build! :thumbsup:
Postby KingAirNeal » Fri Nov 11, 2016 10:56 am
We are a little farther along then this. I was reporting for work to fly the red eye from Vegas to Ft Lauderdale. Here is some more...
KingAirNeal
Postby KingAirNeal » Fri Nov 11, 2016 10:59 am
From nothing to something.
KingAirNeal
Postby KingAirNeal » Fri Nov 11, 2016 11:02 am
KingAirNeal
Postby KingAirNeal » Fri Nov 11, 2016 11:03 am
Floor system construction.
KingAirNeal
Postby KingAirNeal » Fri Nov 11, 2016 11:06 am
Installation of 110v and trailer light harness with marker light branches and insulation.
KingAirNeal
Postby KingAirNeal » Fri Nov 11, 2016 11:08 am
Installation of the Timbren 1 Tonne axle-less suspension system.
KingAirNeal
Postby KingAirNeal » Fri Nov 11, 2016 11:14 am
On goes the tongue jack and safety chains, as well as permanent installation of underfloor sheet metal and floor system.
KingAirNeal
Postby QueticoBill » Fri Nov 11, 2016 12:13 pm
Wow! I'm impressed with progress and all from scratch. Fantastic.
QB
QueticoBill
Images: 22
Postby KingAirNeal » Fri Nov 11, 2016 1:28 pm
QueticoBill wrote:Wow! I'm impressed with progress and all from scratch. Fantastic.
Thanks! So far it has been a bit easier then I thought it would be. I am loving the challenge. The problem solving has been fun, while the cutting of the plywood has been extremely stressful.
Neither my table saw or my circular saw guides are worth a damn...
KingAirNeal
Postby djohnsonnv » Fri Nov 11, 2016 2:38 pm
I will be following this one. I hope to eventually build a teardrop for some off road use around Vegas. Hopefully I will get a few ideas to borrow from your build.
djohnsonnv
Postby KingAirNeal » Fri Nov 11, 2016 6:45 pm
djohnsonnv wrote:I will be following this one. I hope to eventually build a teardrop for some off road use around Vegas. Hopefully I will get a few ideas to borrow from your build.
I live in Henderson. Hoping to move up to Mt Charleston next year some time.
We can meet up some time and you can come check it out.
KingAirNeal
Postby djohnsonnv » Fri Nov 11, 2016 7:06 pm
Appreciate the invite. I just moved out of Whitney Ranch and am now closer to McCarran. Completely swamped at work lately but would love to see your trailer.
djohnsonnv
Postby OP827 » Fri Nov 11, 2016 7:36 pm
KingAirNeal wrote: ... the cutting of the plywood has been extremely stressful.
What saw guides are you using? I made a diy circular saw guide, same as in the picture below and it works fine, very clean cuts.
It's made out of 1/4 hardboard and MDF trim board. I just clamp on my marks and cut.
Sharp looking trailer build, btw. :thumbsup:
OP827
Images: 414
