Light switch ideas
Re: Light switch ideas
Postby earl84 » Sun Nov 13, 2016 8:54 am
Wow, I appreciate all the input! I am currently leaning toward something like this. http://www.ebay.com/itm/322305014183?_t ... EBIDX%3AIT
May order one switch to see how it looks. I do like the SailorSam switches that are only .78 inches deep quite a bit, though. So many choices. Maybe I should just let the designer, my girlfriend, decide for me, and I'll just keep building, haha.
earl84
Images: 23
Postby Esteban » Sun Nov 13, 2016 1:41 pm
I found a link to www.wiringproducts.com in an Amazon Q&A. They offer an extensive selection of wiring products and switches. They will even custom make and label switch panels www.wiringproducts.com/rocker-switch-panels
Steve - SLO, CA
Esteban
Images: 15
Postby earl84 » Thu Nov 17, 2016 9:16 am
Thanks for the link, Esteban. Wow, those are some really annoying fingernails on that woman, but to each their own.
After discussing with my girlfriend, we're going with the shallow switches from Sailorsam's. Easy to install and look good. Also, sort of keep with the retro feel of our TD. Thank you, everyone.
earl84
Images: 23
Postby RubberGypsy » Fri Nov 25, 2016 1:09 pm
SCwood wrote:
earl84 wrote: My walls are 3/4" framing with 1/8" interior and exterior skins. Can I drill holes and mounts automotive type rocker switches right into the walls? Are the switches that narrow? Or will it require some sort of box being built to mount a panel that the rocker switches or whatever is mounted into?
I had the same setup - 1/8 +3/4 +1/8 and went with rocker switches, but had to build boxes for them. I'd do it again, although I do like the idea of that remote though!
So what does the Sassquatch button do ? and where can I get one?
RubberGypsy
Postby SCwood » Fri Nov 25, 2016 2:26 pm
It's for the porch light, to light up the Sasquatches! I got it off Amazon
SCwood
Postby bobwhite215 » Fri Nov 25, 2016 6:07 pm
I wanted to get a sasquatch switch for the outside lights too, but the wife said no. Wasn't a battle worth fighting.
Sent from my XT1080 using Tapatalk
bobwhite215
One idea...
Postby noseoil » Sat Sep 24, 2022 11:09 am
Here's what I did for switch boxes, any number of switches is possible. Just some copper sheet, scrap plywood, switches & outlets.
159924
137905
noseoil
Images: 670
