Good info! Thanks!
Sent from my SAMSUNG-SM-N915A using Tapatalk
finleycraft wrote:Man I don't know how I haven't seen this build! Maybe its because I finished my build back in 14 and haven't been around much since. But now that I am hoping to get into another build sometime in the next 6 months I am searching for inspiration again. This thing is amazing!!!Truly a work of art. Cheers!
Do you have an estimate of the total weight yet? I am curious how it will tow once loaded. I know that in mine it ended up being almost 7x12 and I didn't move the wheels back from the original popup location like yours. If I loaded things too much on top of the wheels or too many cases of water/ beer in the galley it would have a tiny bit of sway above 65mph. That was easily fixed by moving about 50-100 lbs of cargo as far forward as I could get it. Tested it up to 80mph after that on a cross country trip with no sway at all. I like my trailer level and balanced properly.
Every time I see a trailer tongue pointed at the ground or sky I want to smack that driver and send him to driving school.
I have seen the black boat of y'alls here in Kent Washington is that an older body just used to drum up some business?
Again man incredible build can't wait to see the finished product!
Philip wrote:Atomic77 wrote:I'm surprised as well. Not only is the wood here outrageously priced, it's all junk! I remember years ago when we had a "nice" project going on, we would go to the local lumberyard where they had anything and everything you wanted in beautiful quality. Eventually the local yard went out of business and we had to drive 20 miles to Kokomo to go to Carter Lumber. Then it was Furrows. And Big C Lumber. Now all we have is Menards and Lowes and the quality is absolutely horrible. It's your basic homeowner crap. Nothing of quality for a craftsman that's for sure.
If your close enough to run to Kokomo. Peru has a lumber yard. They keep 1/4" cabinet grade ply in stock. It is exterior glue. Its a lot better than the ply in the box stores at Kokomo. Price was $5 a sheet above the trash price at the box stores.
They are currently out. I cleaned out all they had on Monday. They are reordering another skid.
Philip wrote:Midland Lumber Co 101 Washington Ave 765-473-3646
Philip wrote:I had to make a lumber run a few minutes ago. The owner told me they have a skid of 1/4" ply on order. It should be in by the end of the week.
Atomic77 wrote:Philip wrote:I had to make a lumber run a few minutes ago. The owner told me they have a skid of 1/4" ply on order. It should be in by the end of the week.
Thanks! How's the veneer on that plywood?
Atomic77 wrote:The problem I'm having is the veneer is so thin every cut we make chips the veneer. Even after taping both sides it still chips just moving it around and installing. Such a pain.
