Escape Hatch?
Re: Escape Hatch?
Postby AnthonyH » Mon Nov 21, 2016 9:41 pm
I have a ramp back door on my CTC and will be installing gate latches to lock from the inside. That opens up a huge escape route if I can't get to the door. That doesn't stop someone from pulling a prank and locking me in with the outside bar locks though. I do have a big window that opens though.
Sent from my SM-N910V using Tapatalk
__________
Anthony
AnthonyH
Re: Escape Hatch?
Postby OverTheTopCargoTrailer » Fri Nov 25, 2016 12:59 pm
Gonefishing
LOLROTF, right now my ditigal lock with back up key - BROKE ON THE MECHANISM, can't open door from inside or outside even with the key or thumb latch, lucky I was on the outside when it happened because my door is reinforced & it's not easy to remove lock from the interior as it has 4 screws. There is not even a widow to kick out
:x :? :x :? :frightened:
Cheers ottct
Re: Escape Hatch?
Postby EZDog » Fri Nov 25, 2016 4:56 pm
OverTheTopCargoTrailer wrote:Gonefishing
Cheers ottct
If you are going to kick the Widow please dont brag about it!
But seriously what are you talking about?
EZDog
Re: Escape Hatch?
Postby lrrowe » Sat Nov 26, 2016 7:34 pm
I had friends of my parents killed in a mobile home fire. I believe they were trapped and had no way to escape. That event has always been on my mind and perhaps why I am overly cautious about an escape route....who knows? I have a large window which I could "kick" or just push out as the case may require.
Bob
lrrowe
Images: 439
Re: Escape Hatch?
Postby McDave » Sun Nov 27, 2016 3:00 pm
Hey Sleeps,
Have you been following this one.....viewtopic.php?f=42&t=67506
I can see some possibilities for an escape here. Also here....viewtopic.php?t=51721&p=953331
McDave
McDave
Images: 412
