Window sealing (waterprooing)Thinking ahead
Postby rustytoolss » Sun Nov 20, 2016 12:12 pm
In thinking ahead. How did most of you guys seal/waterproof your windows frames to the foam/canvas body ? I know that RV's use gray butyl tape (which may be costly) , I was thinking of using 100% silicone in the large gun tubes. But these are just my ideas :NC
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: Window sealing (waterprooing)Thinking ahead
Postby bonnie » Sun Nov 20, 2016 1:05 pm
I am using butyl tape and an bead of waterproof caulk around the outside edge.
Remember, the turtle won. :)
bonnie
Images: 107
Postby ghcoe » Sun Nov 20, 2016 2:08 pm
I used butyl tape on my clamp ring style windows. I personally do not like the silicone style sealers.
George.
ghcoe
Postby Don L. » Sun Nov 20, 2016 9:32 pm
I used a lot of this stuff - http://www.homedepot.com/p/Loctite-9-fl ... /205451965
It's paintable and pretty strong and cleans up with water.
Link to my foamie camper build viewtopic.php?f=55&t=67321
instagram #don_leister_violin.rva
Don L.
Postby tony.latham » Sun Nov 20, 2016 9:48 pm
It's about $10 for 30'. I use it in some sealing applications but the fact that the general RV industry uses it for their cranked-out junk should tell you something.
Without a doubt, the best sealants these days are polyurethane based. One problem with silicone is that it adheres poorly to something that has been siliconed before.
Postby rowerwet » Mon Nov 21, 2016 12:56 pm
My windows have no seals, being wiley windows they float loose in the window frame, and are held shut with foam wedges.
Of course I never shut the windows unless it is a really cool night when camping, the rest of the year the windows are open, and my tear is stored outside year round.
rowerwet
Images: 521
Postby AnthonyH » Mon Nov 21, 2016 9:25 pm
ProFlex RV is what I used. Factory CT builder just used a small bead of silicone around the outside edges of the frame. I did it right when I had to take windows out to insulate the walls.
Sent from my SM-N910V using Tapatalk
__________
Anthony
AnthonyH
Postby GPW » Tue Nov 22, 2016 8:46 am
3M 5200 marine adhesive sealant ... if we ever want to remove them we’ll have to cut them out ...
We Never use anything the RV industry uses , because it’s "DESIGNED TO FAIL “ ... Failure is the basis of their economy ... :thumbdown:
Postby bonnie » Tue Nov 22, 2016 7:40 pm
GPW wrote:3M 5200 marine adhesive sealant ... if we ever want to remove them we’ll have to cut them out ...
I used 5200 to mount the frames and piece of spacer foam. They aren't going anywhere.
bonnie
Images: 107
Postby aggie79 » Wed Nov 23, 2016 9:58 am
On my teardrop I used 3M 4200 under the trim. It is also a marine adhesive sealant but according to 3M it will allow disassembly of parts as compared to the 5200 which is for permanent mounting. The 4200 seems to be pretty permanent though.
For my windows, I used butyl tape, retightened the mounting screws and removed the squeeze out after a month or so, and ran a bead of OSI quad sealant around the perimeter of the windows. I did this instead of using the 4200, in case I ever needed to remove the windows.
Postby Tomterrific » Thu Nov 24, 2016 11:09 am
I used an old time product called rope caulk. It is a never drying caulk similar to modeling clay. In the summer it is soft enough to get some squeeze out so it is easy to get a waterproof seal. I use it as a bedding compound for the roof vent, windows and hinges. It should be relatively easy to remove said parts for repair or replacement. I don't know if this is the best compound to use but I liked using it.
Tomterrific
