5 by 5" thin plywood in San Antonio
Moderator: 2bits
Postby Dan242 » Fri Nov 25, 2016 1:22 pm
Hi, I did a search, but either my skills are weak or not there. Anybody know of any sources of 1/8" (apprx) 5' by 5' plywood in SA area? This will be exterior and interior walls. Thanks, Dan
Dan242
Images: 25
Re: 5 by 5" thin plywood in San Antonio
Postby tony.latham » Fri Nov 25, 2016 5:26 pm
Dan242 wrote:Hi, I did a search, but either my skills are weak or not there. Anybody know of any sources of 1/8" (apprx) 5' by 5' plywood in SA area? This will be exterior and interior walls. Thanks, Dan
Where did you look? I think DIY's get too focused in on the box stores. Menards, Home Depot, and Lowes.
Get on your phone and call up the lumber yards and ask for 1/8" Baltic Birch.
Here's your list: https://www.google.com/webhp?sourceid=c ... io+plywood
Postby Dan242 » Sat Nov 26, 2016 9:29 am
Thanks for the PM and reply, Gives me some thing to work with, I have a couple of options at this time as far as my construction, so when i get a bit closer to those walls, I'll make some calls.
Dan242
Images: 25
Postby Woodbutcher » Sat Nov 26, 2016 11:16 am
Near Chicago we have a few specialty lumber stores. They sell Baltic Birch 5 X 5 FT sheets 1/8". Some places call it Finnish Birch. I just bought 4x8 sheets of 1/8th inch birch for 8 bucks a sheet at a trailer salvage store. You might also try smaller custom cabinet shops. They can order things from distributors that big box stores don't, or won't do for you.
Woodbutcher
Postby Fishingtomatoseed » Sun Dec 18, 2016 6:50 pm
If there is a McCoys near you I believe they can order it. Also here in Dallas I bought my materials at Central Hardwoods.
Fishingtomatoseed
Images: 9
Re: 5 by 5
Postby 2bits » Wed Dec 21, 2016 12:19 am
Fishingtomatoseed wrote:If there is a McCoys near you I believe they can order it. Also here in Dallas I bought my materials at Central Hardwoods.
Good tip on McCoys. there is one 10 min from me and I might need some thin stuff sometimes!
Thomas
2bits
2bit Member
Postby HotRod1 » Wed Jan 25, 2017 10:24 pm
Try Dixie Ply. They are a wholesaler but would steer you in the right direction.
I plan on sliding sideways on fire yelling what a ride when the Lord calls me home.
HotRod1
Postby Staryder61 » Fri Dec 29, 2017 10:09 am
Wanted to bump this post for newer people like myself here in Central Texas or South Texas.. :) At a loss at finding 1/8" x 5' x 5' lauan or birch plywood here locally in Temple Tx.. I spent the day determined to get what I needed for the Raven's Nest Build..
I found the following in Austin... Might be worth the drive if you can't find it closer to you in San Antonio..
https://www.finelumber.com/solid-panel-inventory
What they have on the list they keep in stock... When I called they were very helpful.. :thumbsup:
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby tony.latham » Sat Dec 30, 2017 10:45 am
I've found it a common practice for lumberyards to order what they don't have in stock.
Postby Staryder61 » Sat Dec 30, 2017 11:24 am
tony.latham wrote:I've found it a common practice for lumberyards to order what they don't have in stock.
I thought so too, Tony
Apparently our main lumber yard. Has went commercial. (Selling to contractors).
Was a disappointment. :(
Years ago when I had a small cabinet shop.. They would sell to everyone. If they didn't have it they would order it..
And the quality was excellent..
Now say they can't compete with the big box stores on most things.
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby tony.latham » Sat Dec 30, 2017 11:34 am
Sorry to hear that... glad I live where I do. Again.
Postby Staryder61 » Sat Dec 30, 2017 1:28 pm
Tony, Your signature picture is a beautiful picture. Is that close to where you live?
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby tony.latham » Sat Dec 30, 2017 3:46 pm
Staryder61 wrote:Tony, Your signature picture is a beautiful picture. Is that close to where you live?
Nope. That's near Lee's Ferry in northern Arizona.
T
Postby Dan242 » Sun Dec 31, 2017 12:30 am
Time/ energy and money constrained me to using standard 4x8. With the magic of PL glue, it's all good.
Dan242
Images: 25
Return to South Central
