Lifting roof XPStream - making improvements
Re: Foldable foamie hybrid trailer
Postby OP827 » Tue Nov 29, 2016 12:12 pm
This video shows manufactured RV propane lines protection.
https://youtu.be/yxFOLUy50bg?t=3
OP827
Images: 414
Postby OP827 » Wed Nov 30, 2016 6:15 pm
Making progress with kitchen, dry fit. Will do furnace and fridge vent openings prior to fixing this cabinet permanently in place.
Left from kitchen is the bed frame coming up.
OP827
Images: 414
Postby Atomic77 » Wed Nov 30, 2016 6:23 pm
Hi Oleg, sorry for the delay.
As far as my LP set up goes, it's actually about as standard as you can get. Most all manufactured RV's have a similar set up and I think it's the best for all around safety, reliability and durability. From the propane tank, I have a standard flexible hose with a regulator. That goes to a black steel pipe under the coach that runs 3/4 of the length of the coach. From there, there is a brass coupler that joins the black pipe to the copper which comes up through the floor. I have the header I built to distribute the LP to the four appliances with shut off valves for each. On most manufactured RV's they usually just "T" at the appliance and run on to the next appliance, with another "T" and so on. Brass should always be used to join the black pipe to the copper. I chose this route for the same reason that most RV manufacturers do... The black pipe can run the length of the coach underneath with nary a fear of anything damaging it. Copper is soft and wears easily. Not something I would want to have to worry about.
Hope this helps!
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Postby OP827 » Thu Dec 01, 2016 1:04 am
Thanks for typical RV propane system information Michael, I did not know those details and it certainly helps. :thumbsup:
Oleg
OP827
Images: 414
Postby Atomic77 » Thu Dec 01, 2016 3:08 pm
Oleg your cabinet building skills are awesome! Have you built cabinets before? Really looking fantastic. Also, do you like the Flame King cooktop? How is the finish, etc.?
Sent from my SAMSUNG-SM-N915A using Tapatalk
Michael
The Astroliner
Atomic77
Images: 309
Postby dales133 » Thu Dec 01, 2016 3:23 pm
Looking good oleg.
Those cabinetts look sweet.
Garden hose over the coper works.
You can actualy buy coper here with a hose already fitted for hot water use
dales133
Postby OP827 » Thu Dec 01, 2016 7:59 pm
Thanks guys. No, I did not build cabinets before, just an "amateur with some youtube experience" :lol:. I do have some good table saw and router and built some jigs though. Flame king cooktop, it looks as in pictures and will do fine in the camper. Finish is good, I just do not understand why the crome top edge has curved openings on the sides and back.. I was also a little bit caught off guard with its hookup in the back, was not expecting that. It will require some creative shielding to propect the copper gas feed line from being heated off refrigerator heater under it. I was expecting that the line could be ran from side as well, as it is in atwood stove. I guess the manufacturer logic was that if someone connects in with a rubber hose, the heat from cooktop is not going to affect it.. kind of foolproof idea, but at the cost of installation options. Will work around it.
OP827
Images: 414
Postby OP827 » Thu Dec 01, 2016 8:42 pm
It's funny, I've started this build as an experiment for a prototype lifting roof and then test it in various conditions, but then I drifted from testing structural properties finding myself working on interior detail. I guess it shows I have a lot of confidence (or wishful thinking) that this concept will actually work in the real travel camping world..
OP827
Images: 414
Postby Atomic77 » Thu Dec 01, 2016 8:47 pm
Oleg, do you have facebook? I saw a cool vintage movie about a foldable trailer but I can't seem to share it anywhere but fb.
Michael
The Astroliner
Atomic77
Images: 309
Postby OP827 » Thu Dec 01, 2016 11:59 pm
I just sent you PM.
OP827
Images: 414
Postby OP827 » Sat Dec 03, 2016 8:31 pm
Today's progress update:
:snappy:
Fridge and furnace vent openings in the side wall are cut and kitchen cabinet with partial back bed and one panel of front dinette is now permanently in place.
Epoxy is setting up, garage heater is on.
And this detail shows a rounded corner that dinette seating will have, someone's toes in the future might thank that round corner.
:wine:
OP827
Images: 414
Postby Atomic77 » Sat Dec 03, 2016 8:35 pm
Looks exceptional! Progress like that has to feel good
Michael
The Astroliner
Atomic77
Images: 309
Postby Atomic77 » Sat Dec 03, 2016 8:43 pm
Oleg, I'm trying to figure out what you are referring to regarding the chrome on the Flame King. Curious. :thinking:
Michael
The Astroliner
Atomic77
Images: 309
Postby OP827 » Sat Dec 03, 2016 9:17 pm
Atomic77 wrote:Oleg, I'm trying to figure out what you are referring to regarding the chrome on the Flame King. Curious. :thinking:
Sorry, not chrome, but stainless steel top. It has cutouts on the sides and back, must be for ventilation so lower enclosure does not get too hot, I think, see the picture I did below.
My tent trailer cooktop did not have those.
OP827
Images: 414
Postby Atomic77 » Sat Dec 03, 2016 9:23 pm
Ok, now I understand. Thank you!
Michael
The Astroliner
Atomic77
Images: 309
