Can someone take a look and tell me what the measurement is?
Johnny
noseoil wrote:Start at the front & work back. The mattress is the biggest thing you need to consider, so do a layout stick with the walls, hatch, bulkheads etc. & see what's left over for the galley. Also depends on the overall length you're working with as to what's left over for a galley.
noseoil wrote:Johnny, we did the same thing with our Benroy. At 5' X 9' LOA you can have a decent galley, a full size mattress & a bit of storage. 8' is pretty small for a good sized galley, if there's a stove & ice chest in the plan. 9' just works out much better in general. Take a look at layouts for 9' trailers & you'll see how the extra foot makes a huge difference in available space. A full sized layout will really help with the planning.
A 1X2 that is the length of your build will let you make adjustments before you cut any materials, it really helps to see things first & avoid mistakes later.
booyah wrote:dont forget to factor in the thickness of the walls in that stick... Mines an 8x5 and I had to cut a few inches off the bed length to fit the cooler in the galley. Not a huge deal, I'm the biggest in the family at 6', but a taller person might miss those few inches.
