Interior design/construction question
Postby Clay » Mon Jun 26, 2006 9:35 am
So the wife and I have decided to "wallpaper" the ceiling panels of The Weekender with maps from our region (Rockies). Anybody have any ideas/suggestions for best way to do this. Apply with thinned construction glue? Some sort of coating afterwards? What do you think?
Clay
Images: 22
Postby WhiteRaider » Mon Jun 26, 2006 10:01 am
Nice idea! I have no idea if these would work, but here are a couple of ideas... perhaps you could glue it to some real wallpaper and, after it dries, apply it as you would regular wallpaper. Or, create an image with all of the maps and get them printed out on plotter paper at Kinkos so it could be applied as one sheet.
WhiteRaider
Postby Gage » Mon Jun 26, 2006 10:25 am
Don't they make wall paper glue for the wall paper that isn't preglued? They used too. Mix with water, soak wall paper and then apply.
Have a good day.
:thinking:
Image Image Image
Gage
Images: 28
Postby Yahnozha » Mon Jun 26, 2006 10:57 am
I guess it depends if you want it permanently on there. 3M 77 spray adhesive is some gosh darn good stuff. I used it to hang stainless steel sheet in a bathroom one time, and it lasted. You gotta spray both surfaces and let them tack before adhering it, oh and you only get one shot at getting it right. Good luck!
P@ = Pat, yep that simple
Yahnozha
Postby cracker39 » Mon Jun 26, 2006 3:28 pm
I've hung wallpaper using the old tried and true method of mixing flour and water to form a paste...it works. But for this application, I think I'd get a decopage kit. I've read about thinning Elmer's white glue with water to attach and cover the paper to protect it. Then, a spray on clear coat could be applied to seal it.
Dale
cracker39
Images: 233
Postby 48Rob » Mon Jun 26, 2006 5:36 pm
I tried something similar once, and it works well, but if there is printing on the reverse, it will show through.
Once you have the paper wet, it becomes somewhat transparent.
Maybe if you sealed the reverse first, it wouldn't?
Rob
48Rob
Postby dacrazyrn » Mon Jun 26, 2006 9:13 pm
I am planning to Paper 'Plique my walls and ceiling. This may work the same for this.
Paper 'Plique
Another
Brown bag walls
dacrazyrn
Images: 74
Postby GPW » Tue Jun 27, 2006 7:12 am
Cracker's right on about the Decopage kits , or the materials alone ... Any good craft store will have a good supply of the materials you need(Real easy !!!) ... Maps on the wall , a nice wainscoting, turned post , a Parrot on a ring ....???? Sounds like a Pirate ship ... ARRRRRRRRR!!!!!! :lol:
Postby Miriam C. » Tue Jun 27, 2006 9:41 am
Hi guys,
If you use wall paper paiste (I would) don't put it on top of your map. The poly might not stick to it. I would cover with a good external clear poly. That way if you have moisture form on the walls it will stay nice.
You can also use watered down white school glue. That is all Decopage glue is. Years ago my sister did a table with all our pictures and it is still in good condition.
Aunti M
teardrop construction tips & techniques
Postby KA » Tue Jun 27, 2006 12:12 pm
Hi,
You could do a little test sample with acrylic mat medium found in art supply stores. It is expensive, though. It comes in mat and gloss finishes and is used in collage.
I also read about a torn paper bag technique that uses acrylic polymer. I believe that article was on one of the Cheapskate or Tightwad websites. You use the polymer under and over the paper as glue and then when dry you apply about 6 coats as a sealer. If it starts to wear out you just add more torn bags. The effect is supposed to look like leather. I plan to use the torn bag technique with the additon of some other paper and artwork on the floor of my teardrop. I figure this will be a good place to experiment since it will be under the mattress. One potential problem with this is that the mattress could stick to it. So, it will be an experiment.
KA
KA
Images: 9
Postby MeelisV » Tue Jun 27, 2006 1:42 pm
we have paper type wallpaper on side walls and something like felt on ceiling and back wall, there is no special cover on wallpaper
you can change it when ever you like or need.
A woman has the last word in any argument.
Anything a man says after that is the beginning of a new argument.
MeelisV
Images: 105
Users browsing this forum: Google [Bot] and 1 guest
