mariannf wrote:I am considering a new build. I am thinking about buying an old pop up trailer (canvas sides) and converting it to a hard side travel trailer.
Do you know of any examples of this being done well? any tips or advice?
Doublacola wrote:I assume you want to leave the top and bottom and just replace the canvas with hard walls, leaving it up permanently ? That's what I'd like to do also but cannot find anything that looks really good. I've seen a few done but they don't look nice. If you do it keep us informed.
Good luck
Richard
mariannf wrote:Doublacola wrote:I assume you want to leave the top and bottom and just replace the canvas with hard walls, leaving it up permanently ? That's what I'd like to do also but cannot find anything that looks really good. I've seen a few done but they don't look nice. If you do it keep us informed.
Good luck
Richard
thanks Richard and Tlsallada.
Right Richard i am interested in using the base and the roof and replacing the canvas with hard side material. Thinking about it still...i f i come up with anything i'll post back here.
S. Heisley wrote:
Under that thought, I'd be tempted to do something a little differently...maybe. If it's just the canvas that's bothering you, why not make removable foamie walls to replace the canvas? That way you might have the best of both worlds: low travel profile and ability to stand when the top is up. This would also allow you to use it now, while you work on your hard wall idea, too. Styrofoam is inexpensive, light weight, and somewhat forgiving to work with. Do you already have the pop-up?
S. Heisley wrote:mariannf wrote:Doublacola wrote:I assume you want to leave the top and bottom and just replace the canvas with hard walls, leaving it up permanently ? That's what I'd like to do also but cannot find anything that looks really good. I've seen a few done but they don't look nice. If you do it keep us informed.
Good luck
Richard
Doublacola wrote:This is along the lines of what i've been thinking about. I would add several windows.
http://www.doityourselfrv.com/vintage-a ... rt-studio/
jandmz wrote:Doublacola wrote:This is along the lines of what i've been thinking about. I would add several windows.
The Apache people will try to talk you out of it. They get kinda sensitive about destroying an Apache.
There were a couple years that Apache campers could be ordered without bed ends. They are the shape that you are considering, retain the low profile towing advantages of a popup, and would require zero work converting one, other than what you would do to remodel the interior. They are hard to find, but do come available every now and then. I have only ever seen two like this. Here's a link.
http://www.apachepopups.net/albums/albu ... .sized.jpg
