Three's a crowd
Three's a crowd
Postby Dashunde » Fri Jan 06, 2017 8:59 pm
I'm in the early stages of my teardrop plan and I'm a bit stumped... where to put a bunk for my 4 year old (and growing fast) daughter?
I want to stick with a relatively simple aluminum/ply teardrop with a mostly flat'ish roof (possible a/c unit) and mostly flat'ish front panel with a gentle radius into the roof.
Same for the rear.. a gentle bowing hatch.
A queen size bed is a must.
I'm shooting for the 5x9 range?
Where are the rest of you putting your kid(s)?
Dashunde
Re: Three's a crowd
Postby KennethW » Fri Jan 06, 2017 9:09 pm
I would go 5'x9 1/2' (18" overhanging the front) with a straight galley wall(no cabinets) and put a 2' x 5' bunk over your feet.
KennethW
Images: 82
Re: Three's a crowd
Postby Tombo_ontario » Fri Jan 06, 2017 9:10 pm
Ive been planning a build for a while now and have a little one as well. Ive decided (for myself atleast) that the best option for a bunk is at the rear of the teardrop perpendicular to normal sleeping position in a teardrop. Ill sacrifice a little kitchen space out back to extend what is essentially the countertop into the main cabin of the trailer to act as a bunk. I figure that if my trailer is 5' or 5.5' wide then my daughter will be able to use it for years before being too tall.
Tombo_ontario
Re: Three's a crowd
Postby Dashunde » Sat Jan 07, 2017 12:01 am
It does seem that above our feet is the only sensible place to put a small bunk...
Been rethinking the rooftop a/c thing.. too big, too pricey for most.
I'll probably go with the $150 window/boxy type, and a fan in the roof instead.
The kids bunk will kind of interfere with the a/c box placement?
Dashunde
Re: Three's a crowd
Postby tony.latham » Sat Jan 07, 2017 12:28 am
I'v always admired this build to solve the add-a-kid kid problem: viewtopic.php?f=50&t=59086&start=195
Re: Three's a crowd
Postby Vedette » Sat Jan 07, 2017 11:10 am
Check out the "Scad a Bout" trailer built in 1967.
Great design for Teardrop Trailer enthusiasts that like camping and have 1 or 2 kids.
Can't for the life of me see why these did not take off in popularity???? :thinking:
Good Roads
Brian
PS
I am sure someone will post pictures or a link........I am just technically challenged. :NC
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: Three's a crowd
Postby camper4life » Sat Jan 07, 2017 10:37 pm
I built bunks for my two sons.
125284125283125282
camper4life
Images: 39
Re: Three's a crowd
Postby Dashunde » Sat Jan 07, 2017 10:58 pm
Dashunde
Re: Three's a crowd
Postby Dashunde » Sat Jan 07, 2017 11:06 pm
camper4life wrote:I built bunks for my two sons.
125284125283125282
I really like your layout.. a lot. Great use of space... 4 people, full galley, storage and a/c. :thumbsup:
What is your side panel height?
Dashunde
Re: Three's a crowd
Postby camper4life » Sun Jan 08, 2017 12:26 am
Thanks! I can't find many pictures of the a/c window unit installed on the drivers side of trailer. In this picture, there is a flip up door next to window. I install a/c when I arrive and depart from campsite.146539
camper4life
Images: 39
Re: Three's a crowd
Postby bobwhite215 » Mon Jan 09, 2017 11:54 pm
Maybe a hammock?
Sent from my SM-T817V using Tapatalk
bobwhite215
Re: Three's a crowd
Postby jandmz » Tue Jan 10, 2017 12:50 am
We are empty nesters, but there was a family in the campground last season that had a teardrop with a rooftop tent. One parent was in the TD with one child and the other parent was in the RTT with the other. Their plan was to get back together when the kids got old enough to spend the night in the RTT alone.
jandmz
Re: Three's a crowd
Postby yrock87 » Tue Jan 10, 2017 1:28 pm
I have a crosswise bunk across our feet for my kiddo. the tear is 5 wide so there is PLENTY of room for her at 18 months. and there is tons of room to grow into it. we currently have a pack n' play style mattress cover over two of the visible memory foam chunks on one side of the bunk, it takes up about 3/5th of the length, leaving the other two feet for our duffels. when my little girl isn't so little any more, we will extend the bed space of the bunk. I do still need to figure out a workable cabinet situation that leave room for the bunk, but as pictured got us through a week long thanksgiving roadtrip well.
edit- oh, mine ended up being a 5x10 benroy because it provided plenty of room for a bunk. I feel like we would be tight trying to fit the bunk into a smaller tear and still ending up with usable space in the galley, ext. doable, but tight.
yrock87
Images: 97
Re: Three's a crowd
Postby booyah » Fri Jan 13, 2017 2:18 pm
We regularly fit 3 in mine, including a 12 year old (right about 5'). 4 in a pinch (one on the bed in the middle)
I have no internal cabinets, but a comfy "kid bunk" over the feet of mom and dad.
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Re: Three's a crowd
Postby lacustom » Fri Jan 13, 2017 11:04 pm
Our trailer is 6x10
We can fit three next to each other plus the pull out bunk
Lou Piscitelli
If you can dream it ,we can build it!
lacustom
