Chesapeake Light Craft Teardrop Trailer
Re: Chesapeake Light Craft Teardrop Trailer
Postby KingAirNeal » Sat Jan 14, 2017 10:14 pm
KingAirNeal
Postby friz » Sun Jan 15, 2017 5:42 pm
Hinges gluedImageImageImage
Sent from my Altair 8800 using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Postby pchast » Sun Jan 15, 2017 9:06 pm
Interesting approach to hinges. How did things line up for the doors?
Did it take a lot of adjustment? Are they tight and strong enough as is
or do you need to fillet and glass more support?
:thinking:
pchast
Images: 97
Postby friz » Sun Jan 15, 2017 9:36 pm
Fillets will come later. The hinges are already glassed on both sides.
The "Sin Bin"
150133
friz
Images: 6
Postby friz » Mon Jan 16, 2017 7:47 pm
The hinges hinge!Image
The "Sin Bin"
150133
friz
Images: 6
Postby KingAirNeal » Mon Jan 16, 2017 9:23 pm
Well done! Looks amazing!
KingAirNeal
Postby friz » Mon Jan 16, 2017 9:48 pm
KingAirNeal wrote:Well done! Looks amazing!
Thanks.
Working gaps on the hatch.
The "Sin Bin"
150133
friz
Images: 6
Postby Breytie » Tue Jan 17, 2017 5:14 am
That is NOT a gap - way too neat and even! That, Sir, is a parting line.
Bloody beautiful work, I must say!
Experience is learning from your own mistakes
Here I make mine in public: My build
Breytie
Images: 36
Postby deoc4114 » Tue Jan 17, 2017 8:39 am
That's a beautiful looking trailer.
Couple questions for some thoughts of my own:
- what are the general dimensions of the galley?
- could this be constructed without cutting the galley opening?
I ask this because we're looking for designs to fit my wife, my daughter, and myself. If we could make the galley a bunk area for her - with a passthrough to the main sleeping area of course - this could be added to our short list of considerations.
I have a feeling the trailer would be overall a bit too small for the three of us, but it could be an interesting idea if it worked.
Dan
deoc4114
Postby MadMango » Tue Jan 17, 2017 9:06 am
Awesome progress and workmanship!
:applause:
MadMango
"Art without engineering is dreaming; Engineering without art is calculating." ~Quentin Stafford-Fraser
You can see my design planning, The Mobile Mango.
You can follow my TTT build here, The Mobile Mango
MadMango
Postby friz » Tue Jan 17, 2017 10:00 am
The galley is roughly 60 inches wide. Yes it could be built without cutting the galley hatch. Yes, a pass through could be cut in the bulkhead between the cabin and galley. I still may do this because of limited storage in the cabin.
The "Sin Bin"
150133
friz
Images: 6
Postby Rygolf32 » Wed Jan 18, 2017 12:52 pm
Brand new here but found this thread and it is looking amazing friz. Way to go and can't wait to see the finished product! There is no doubt that'll be a head turner when out on the road! :thumbsup:
Trailer - 2019 7x12 Pace American Journey SE
Tow Vehicle - 2009 Chevrolet Silverado LTZ
Rygolf32
Images: 16
Postby friz » Fri Jan 20, 2017 11:08 am
More filletsImageImageImage
The "Sin Bin"
150133
friz
Images: 6
Postby Alan_H » Sat Jan 21, 2017 4:24 pm
Very nice!! How do they suggest addressing water penetration to the wood that is exposed in the holes for the hinge pins?
Also, what thickness is the plywood that is used for the shell?
Alan_H
Postby pohukai » Sat Jan 21, 2017 5:24 pm
I can't speak for CLC addressing hole like this but one technique is :
1) Drill an oversized hole, perhaps 1/8" larger.
2) Fill hole completely with epoxy
3) When the epoxy has completely cured, redrill the hole to the hole size needed. This should leave about 1/16" epoxy ring inside, protecting the wood inside the pin.
All of this is done before mounting, so CLC may have recommended something different.
Alan_H wrote:Very nice!! How do they suggest addressing water penetration to the wood that is exposed in the holes for the hinge pins?
pohukai
Images: 9
