plunging on another build
Re: plunging on another build
Postby flboy » Mon Oct 31, 2016 7:05 pm
Thanks Hank.. I should've been more specific.. I was interested in the "store" Larry bought the awning from... The brand is easy to find as you know.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby hankaye » Mon Oct 31, 2016 8:00 pm
flboy, Howdy;
Ok, ... then try this link to their Dealer Locator;
https://www.e-carefree.com/ecarefree30/dealersearch
hank
hankaye
Postby Wolfscout » Tue Nov 01, 2016 8:02 am
flboy wrote:Did you figure out how you would mount it with your side window so close to the roofline?
Btw.. can you send me a link for the awning? I need one the same size and I am ready to install at any time now. Thanks.
I purchased mine from this ebay dealer:
http://www.ebay.com/itm/111797641603?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I had already purchased and installed two sections of 8" awning rail that I purchase from http://www.vintagetrailersupply.com/Awning-Rail-90-degree-p/vts-876.htm $14.99 x2 plus shipping and a tube.
I'm just hoping my "Guesstimate" as to the end of the left side is going to hit that stud just like I plan. Having 16 foot of rail I hope is going to take care of that.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby Wolfscout » Tue Nov 22, 2016 4:54 pm
I finally got my Awning put up this weekend. Carefree Pioneer 15' with black fade fabric.
This one shows the awning rail just beneath the ladder rack. :)
I like it.
Next project, I was told by the wife, is for forget that portapotty and get her a flushable toilet in side before out next trip. :shock: :?
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby aggie79 » Wed Nov 23, 2016 9:28 am
Larry,
That awning looks great! Congratulations. :thumbsup: :applause: :thumbsup:
I'm curious. How hard was the installation? I was wondering because if I ever get to do a cargo trailer conversion, I'll need to build it a little bit at a time as I have the money to do so.
Take care,
Postby Wolfscout » Thu Nov 24, 2016 2:23 pm
That's How I been going. This is my second build. The awning install wasn't that bad. Took three of us about 20 minutes to put it on.
Got Wife's toilet installed this AM. water lines hooked up. have to test them another day + caulk up the underneath plumbing.
It fit right nicely where I had the referigerator and the counter top. refrig is being moved to back of the camper.
My toilet sewer outlet is nice tight and high underneath. Might have to set a portable tank under there sometimes. Alittle caulk and I'm done.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby Padilen » Fri Nov 25, 2016 7:38 am
Hey just wanted to mention a possible issue with a portable tank. Before my axle flip, my portable tank wouldn't fit under my trailer. Also connected by sewer hose the connection into tank was higher than my flush valve. Since mine is a combo toilet/tank (5gallon), I just used my portable to drain my holding tank. After draining I'd remove hose from flush valve first. Lifting it to clear any solids.
Padilen
Postby Wolfscout » Fri Dec 02, 2016 5:09 pm
I've had a problem like that in the past with the tub/sink sewer exit plumbing. I don't use a holding tank, just the portables.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby Wolfscout » Thu Jan 19, 2017 6:24 am
We camped at the State Fair Grounds the other week. My wife works for the company that was holding a distribution vender show.
I got to test a lot of the things I've added on.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby Dieselmike1 » Sat Feb 18, 2017 10:32 am
I was wondering how that tacoma handles that size trailer, do you know what the weight of your finished trailer is? Very nice build by the way! :thumbsup:
Dieselmike1
Postby Wolfscout » Tue Mar 21, 2017 2:58 am
Our Toyota Tacoma pulls this trailer nicely. We did have to go with weight distribution and sway bar(s). Compared to my similar Ford Explorer that barely pulled it home brand new and empty.
I do not know the weight of my trailer, but I'm guesstimating (with golf cart and fishing buggy). To be around 4500lbs. It's probably a bit more.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby faust_21 » Mon May 29, 2017 5:15 pm
Wolfscout wrote:We camped at the State Fair Grounds the other week. My wife works for the company that was holding a distribution vender show.
I have been racking my brain trying to figure out how to plumb my sink and shower together to a waste gate then drain to a portable holding tank. Could you share some pics and list parts for your exit plumbing/adapter. Thanks!
faust_21
Postby aggie79 » Mon May 29, 2017 6:33 pm
This is how Jerry did his shower and sink gray water plumbing on his Retro-Kamper: http://www.tnttt.com/viewtopic.php?p=1067912#p1067912.
Postby Wolfscout » Mon Jun 25, 2018 3:46 pm
Sorry this is late. I've been absent for a good while.
Hope my BS Paint skill can give you an idea.
sewer pipe modification..jpg (187.95 KiB) Viewed 3889 times
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby aggie79 » Tue Jun 26, 2018 10:11 am
It's good to hear from you Larry! :applause:
