Air conditioner
Air conditioner
Postby lacustom » Fri Jan 13, 2017 11:31 pm
Does anyone have any info on the outside ac units that Little guy trailers uses? Do they work well? How much? I like the idea of the whole unit outside
Lou Piscitelli
If you can dream it ,we can build it!
lacustom
Re: Air conditioner
Postby elcam84 » Sat Jan 14, 2017 10:22 am
Not sure off hand and I haven't looked at one in a while but they could be using one of the pet cool units. They are pretty popular for teardrops.
Sent from my SM-T320 using Tapatalk
elcam84
Re: Air conditioner
Postby QueticoBill » Sat Jan 14, 2017 11:24 am
That one that is heater and ac is indeed interesting - if not a little pricey. Thanks for making me aware of these.
PS: Gives new meeting to sleeping in the dog house.
QB
QueticoBill
Images: 22
Re: Air conditioner
Postby jondbar628 » Sun Jan 15, 2017 7:12 pm
As a very wise man on this forum once said, "If you need A/C, you're camping in the wrong place"..........Smooth roads & happy campfires.........DG
jondbar628
Re: Air conditioner
Postby elcam84 » Sun Jan 15, 2017 8:16 pm
jondbar628 wrote:As a very wise man on this forum once said, "If you need A/C, you're camping in the wrong place"..........Smooth roads & happy campfires.........DG
Yeah unfortunately we live in tx where you need AC 9 months out of the year and sometimes even in december... (can't wait till we head somewhere cooler) Very little good camping weather here.
elcam84
Re: Air conditioner
Postby dexstrom » Tue Jan 17, 2017 12:22 am
I have a Climate Rite A/C on my TT, 5,000 btu and it keeps the trailer at 74f in 90+ temps. Did have to get the thermostat because the remote wouldn't work from inside the trailer. This will be the third summer with it and really like it. I think that is the model that Little Guy uses, though it might be the 2,500 btu size which should be enough to cool a teardrop.
dexstrom
Re: Air conditioner
Postby lacustom » Tue Jan 17, 2017 12:48 pm
Thanks , I'm going to look into that
Lou Piscitelli
lacustom
Re: Air conditioner
Postby ocasioc25 » Thu Jan 19, 2017 10:27 am
There's a new ac that will be coming out soon. It's called a Noria window ac. I think it's still on that kick starter but once they go public, it might be a good unit. I have a 5,000 btu unit I slide in a access door once I hit the campsite. Works real good. A lil expensive but better that hauling a big heavy ac.
https://www.kickstarter.com/projects/ku ... -redefined
ocasioc25
Re: Air conditioner
Postby elcam84 » Thu Jan 19, 2017 10:37 am
Looking at the picture of the hardware I'm not impressed. First thought was it was a peltier style unit because of the size. I seriously doubt it will meet the performance they are claiming not to mention it has the look of a kick starter that will fail (unrealistic goals).
elcam84
Re: Air conditioner
Postby Shadow Catcher » Thu Jan 19, 2017 5:53 pm
We had a pet cool which at 2500 BTU did not cut it. I adapted a 5,000 BTU Frigidaire window unit and wrote it up http://tnttt.com/viewtopic.php?f=30&t=44561 . what has been fun is to see what others have done with the idea and improvements on my start.
143657143655143656
Re: Air conditioner
Postby lacustom » Sat Jan 21, 2017 7:17 am
Thanks Shadow Catcher, does that set up seem to work in Aug temps with high humidity? I might try that
Lou Piscitelli
lacustom
Re: Air conditioner
Postby steve cowan » Sat Jan 21, 2017 8:35 am
This has worked well after the learning curve.Camped on the South Carolina and Florida coast during summer [very humid] and put out 3 to 4 gallons condensate a day.
Inside very comfortable.
/[img]gallery/imagehttp://www.tnttt.com.php?album_id=2829&image_id=139099&display=popup[/img]
steve cowan
Images: 207
Re: Air conditioner
Postby elcam84 » Sat Jan 21, 2017 10:55 am
Has anyone seen a 5k btu window unit that was a heat pump? I haven't seen a unit that small. However there are other ways to heat and it's allot easier and cheaper to heat then to cool.
elcam84
Re: Air conditioner
Postby Shadow Catcher » Sat Jan 21, 2017 7:56 pm
We have had a number of 90F 90% humidity trips and have been comfortable, a good amount of condensate on the ground in the morning. One thing to remember the interior of Compass Rose is about 400 cubic feet (large for a tear).
Re: Air conditioner
Postby elcam84 » Sat Jan 21, 2017 8:26 pm
steve cowan wrote:This has worked well after the learning curve.Camped on the South Carolina and Florida coast during summer [very humid] and put out 3 to 4 gallons condensate a day.
That looks like Florida dirty sand. We used to go to Wauchula in Feb until lots dad passed away a couple years ago.
5 gallons of condensate is doing pretty good. When I put the new ac in our house I tempted the drain into a bucket to see how much it produced... Quite a bit. This was before summer and it was producing 5+ gallons a day (3.5 ton unit) it probably produces 4 to 5 times that in the summer.
I could definitely see a drain tube running away from the camper to keep the mud away from it.
elcam84
