Chesapeake Light Craft Teardrop Trailer
Re: Chesapeake Light Craft Teardrop Trailer
Postby friz » Sat Jan 21, 2017 5:52 pm
The holes are already oversized. The hinge bolt is significantly smaller. So I assume the fill and drill method. I am contemplating gluing in some tubing. This epoxy that comes in the kit is some really hard stuff so it may be tougher then an aluminum bushing.
Sent from my Altair 8800 using Tapatalk
The "Sin Bin"
150133
friz
Postby Alan_H » Mon Jan 23, 2017 12:57 pm
Thanks for that... great idea! :applause:
What thickness is the plywood on the shell?
Alan_H
Postby friz » Mon Jan 23, 2017 5:39 pm
Alan_H wrote:Thanks for that... great idea! :applause:
4mm I believe.
The "Sin Bin"
150133
friz
Postby Alan_H » Tue Jan 24, 2017 10:29 pm
I was guessing 4 or 6, I guess 4 works better for the bends, and the stitch & glue method along with the opposing arcs gives it plenty of strength.
Thanks again friz!
Alan_H
Postby tomtnt » Wed Jan 25, 2017 7:04 pm
Alan_H wrote:I was guessing 4 or 6, I guess 4 works better for the bends, and the stitch & glue method along with the opposing arcs gives it plenty of strength.
Thanks again friz!
I'm amazed how strong the structure is- when attempting to place the floor on the shell by myself, I accidentally dropped the extremely heavy floor into the shell and was amazed that there was no damage.
tomtnt
Postby friz » Thu Jan 26, 2017 5:05 pm
Thanks again friz!
Agreed, The strength to weight on these structures is amazing!
The "Sin Bin"
150133
friz
Postby friz » Sun Jan 29, 2017 10:42 pm
The "Sin Bin"
150133
friz
Postby friz » Mon Jan 30, 2017 11:42 pm
Found some lights that are a good fit. Definitely need a dimmer. These are a little bright.
The "Sin Bin"
150133
friz
Postby AzAv8r » Tue Jan 31, 2017 8:38 am
Bright can be good. Looks like they might work really well for the lighting the galley work surface. Where'd you get them?
AzAv8r
Images: 6
Postby lthomas987 » Tue Jan 31, 2017 9:01 am
friz wrote:ImageImage
A dimmer is a great idea! Also depending on the color reflectivity of your interior you might want more light than you think, or in my case(glossy white) way less. Those lights look like they were made for that spot!
Sent from my LGLS991 using Tapatalk
Laura
Bike-Drop a Micro-Foamy Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=59274
My first Superlegarra-ish Foamy build http://www.tnttt.com/viewtopic.php?f=55&t=59049
lthomas987
Images: 204
Postby friz » Tue Jan 31, 2017 11:02 am
The "Sin Bin"
150133
friz
Postby friz » Sat Feb 04, 2017 9:18 pm
Bench testing lights and dimmers.
https://goo.gl/photos/Ka7r7dekUJN5BhKm7
The "Sin Bin"
150133
friz
Postby Dave Gray » Mon Feb 06, 2017 10:49 pm
KingAirNeal wrote:Image
Friz
Your build will sell more CLC tears than their website. You are a craftsman with the medium and now I am considering one as a future build. I am a big fan of WoodenBoats and their lines. My first teardrop build will be Old School and heavy because I plan to haul a lot of Iron and will basically be sleeping in the Chuck Wagon.
I got KingAirNeal to bring you a few more tons of likes for me.
Dave Gray
Dave Gray
Postby KingAirNeal » Mon Feb 06, 2017 11:02 pm
I have a few more like it.
KingAirNeal
Postby friz » Tue Feb 07, 2017 10:09 am
Thanks for the kudos. Truthfully, this medium is pretty forgiving. I would never attempt this without a kit. CLC'S parts are a perfect fit.
The "Sin Bin"
150133
friz
Users browsing this forum: No registered users and 23 guests
