by rruff » Tue Jan 24, 2017 1:20 pm
Wow, lots of replies! I thought I'd be notified. Looks like I came to the right place, you people aren't shy about thinking outside the box!
dancam: I did find a place to get 40 psi EPS semi local (only 150 miles away, Insufoam, Mexican company) but haven't gotten there and I need to see it. I've heard reports that there is a huge variation in structural integrity and QC with EPS, even the heavier stuff. Of the foam I've seen, XPS just seems a lot better.
Spraying fiberglass resin... no. Maybe I'd consider rolling it on. But I think if I wanted to deal with that toxic stuff I'd lay up fiberglass and epoxy over the foam, or polyester resin over plywood over foam. And then you still need a UV layer.
Plastics are interesting, but need their own durable coating for UV that will stick. Unless you pay for Filon. There are reasons why it is expensive.
GPW: How exactly do dents in PMF self-heal in the sun? Does the glue soften that much when it gets hot, and does the foam spring back? Softening might not be a good feature if the "denting objects" (mostly rocks and tree branches in my case) are encountered on a hot day. Or I need to climb on the roof to deal with solar panels. BTW I do want to be able to stand on the roof without damaging the surface or leaving an impression, even on a hot day!
Pmullun503: I looked at Styrospray awhile back and decided against it. Too finicky and not for long UV exposure. Also, I never have humidity over 50% here during the day unless it's raining.
I priced out the materials to build my shell using okoume 3mm ply, wood stringers, XPS from Home Depot, and fiberglass, polyester resin, and gelcoat, and came up with ~$3500. So I'm comfortable with that level of expense, even a little more if it's worth it. The plywood was the biggest expense, ~$1900 shipped. But oddly 400 lb of plywood sheets cost half as much to ship (from a farther distance) as an 18" high stack of foam sheets would have!
I want this thing to be durable and last at least 15 years with minimal maintenance. And it's going to get a lot of use. I don't mind doing experiments before I build, but I don't want the camper itself to be an experiment, ie a "lets see if it falls apart or not". I'm going to take it into the back country, so washboard and pounding over rough roads. And squeezing through tree branches. And twisting through ditches and ravines. I kinda settled on the materials I listed above because I felt comfortable with them, and it's similar to what I've done before. I trust wood bonding to wood a lot more than anything bonding to foam. Even though I love the idea of using little or no wood. This XPS isn't designed for a structural sandwich (even the heavier stuff), and based on reports I've heard from camper and surfboard builders a lot of people have had bubbling and delamination issues when skinning with epoxy fiberglass. Though most of that may be lack of properly texturing the foam.
Anyway I might as well give you a visual of what I'm thinking, with my crappy Paint and Sketchup files. The bottom of the camper bolts directly to the frame. I *am* going to use familiar materials for that! 1/4" plywood sandwich, foam and stringers, fiberglass on both sides.
- Attachments
- Tundra18.jpg (118.41 KiB) Viewed 2379 times
- Camper01.jpg (125.66 KiB) Viewed 2379 times
