Decision time - windows vertical or horizontal?
Postby les45 » Thu Jan 26, 2017 8:28 am
Should the windows in our hard wall pop-up project be vertical or horizontal? The wife and I can't agree on this one so I'm going to put it to a vote here on the Forum.
(these are fixed windows so orientation is not an issue)
les45
Images: 605
Re: Decision time - windows vertical or horizontal?
Postby mary and bob » Thu Jan 26, 2017 8:37 am
Are they sliding windows? If so, they generally slide sideways. If there are weep holes on one side, they go at the bottom.
mary and bob
Postby les45 » Thu Jan 26, 2017 8:59 am
mary and bob wrote:Are they sliding windows? If so, they generally slide sideways. If there are weep holes on one side, they go at the bottom.
Edited original post to explain that these are fixed windows; orientation is only an aesthetic issue.
les45
Images: 605
Postby booyah » Thu Jan 26, 2017 9:35 am
Just one window or more?
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby les45 » Thu Jan 26, 2017 10:05 am
booyah wrote:Just one window or more?
For now, just two windows; one in the panel in the pic and one in the panel directly opposite on the other side. Those are over the dinette area. Nothing over the bed area to the left of the door. May add two in the front end walls later. We will not be spending a lot of time inside except on rainy days and at night so two wall panel windows and the door windows should provide plenty of light. Also don't want to have to mess with a bunch of curtains inside.
les45
Images: 605
Postby booyah » Thu Jan 26, 2017 11:21 am
I would do vertical in the position shown, and be tempted to do a horizontal in the panels on the other side of the door as it looks like a wider panel.
But I'm odd, so fwiw :)
booyah
Postby steve cowan » Thu Jan 26, 2017 5:51 pm
Since you are using it for the dinette area the view would be better going horizontal.The outside look is a tossup.
steve cowan
Images: 207
Postby Philip » Thu Jan 26, 2017 7:05 pm
I think vertical looks best.
Philip
Images: 323
Postby S. Heisley » Thu Jan 26, 2017 7:09 pm
:thinking: I like the horizontal. However, three things to think about are:
1) You'll want the bottom of the window to be even with or higher than the back of the dinette bench chairs.
2) If you put the window in horizontally, you'll be able to see more horizontally without straining to look.
3) If the window is made to slide sideways and you put it in vertically, you'll need to add drainage for the window channel, at its "bottom".
Postby edgeau » Fri Jan 27, 2017 12:13 am
My vote is horizontal. Purely on looks
Sent from my ZTE T84 using Tapatalk
edgeau
Postby les45 » Fri Jan 27, 2017 11:12 am
And the winner is: I decided to go horizontal. That is what my wife wanted in the first place and, after seeing the mockup in the pics, it does look better. I've got all the frameworks ready so I just have to cut the holes in the plywood and fasten everything together today. BTW - the ends will get sloping walls that will extend from the bottom edge of the roof to a shelf that will extend about 15" beyond the top edge of the bottom shell. That gives us a lot of shelf space inside on both ends and breaks up the cube look. I'll be updating my journal in a few days with pics of the panels installed.
Thanks to everyone who provided input.
les45
Images: 605
